Reba seal popped - ...
[Closed] Reba seal popped - help!
 gp
Hi - I have just been trying to adjust the air pressure of my reba xx forks - the grey seal around the top right leg has popped out. Does this need to be re-fitted by someone that knows what they are doing or can I just push it in and hope for the best!?
Thanks
Posted : 15/10/2012 7:56 pm
it's a bigger problem than that. The seal can easily be pushed back into place but you've actually had an internal air seal fail which has pressurised the lower leg (and then forced out the wiper seal). Are they new? If so, get them back under warranty
Used to hear about this problem a lot more often
Posted : 15/10/2012 7:59 pm
 gp
No they arent new - I will take them to a lbs tomorrow - thanks...
Posted : 15/10/2012 8:07 pm
