i have a new pair of reba race forks, and having a bit of a problem regarding set up, i have put about 120psi in both positive and negative valves but it still feels as there is a lack of pressure and no plushness in them, this is the amount of pressure i have in my other rebas and they work great, i have tried increasing with another 20 psi or so and it makes little difference, also when the fork is locked out there is a fair bit of movement still, can anyone point out what the problem may be! thanks in advance
anyone?
I have some Sl's from merlin, got well over 200 psi in mine, can't remember quite how much but was done on trial and error, I'm a 17st pie monster though!
Reba Team Dual Airs
120mm travel
me = 190lbs
90psi in both chambers for a lovely plush feel
had mine about 7 months now started off with 130psi top and bottom and all ive done is reset the top to 120psi and they have been fine but then think when i got mine the concensus was that they take a few rides to bed in
I'm glad you asked this, cos I'm in a similar position.
Got a pair of Reba SLs on the Rockhopper; I've read the destructions that came with it and a few forum posts, but just can't seem to get it 'right'. I think part of the problem is, I don't really understand in my head how the negative air affects things, in contrast to the rebound speed control.
I've currently got it to where I'm using almost the full travel on rides out, but it still feels 'rattly' and I can't quite put my finger on what I need to do about it.
Fork juice! Worked a treat on mine...
Negative air < positive air gives a similar effect to preload on a coil fork. Just stick to equal pressure ± 10 PSI and you can't go too far wrong.
Give them a month to settle in, then give them an oil change & lube the foam rings. My first pair of Revelations had no oil when I got them, they felt shite until I put some oil in.
's pretty much what I've done. Initially set up with the "right" pressure for my weight and -10 for the negative, dropped the +ve pressure when it felt too firm and left the -ve, still doesn't feel right. Guess I need to keep experimenting.
Sorry for the thread hijack by the way, figured the responses should be applicable to both of us.
Just stumbled across this,
http://www.bikeradar.com/forum/viewtopic.php?p=14960293
... sounds like what I need is more -ve air.
hmm ok thanks for the response im only 160lbs and my other rebas feel great at the same pressure could the problem lie with lack of oil in them? is this easy enough to change don't mind having a go myself
