have a pair of 2011 reba 100mm with poploc came on a bike i bought new a year ago
anyway all working fine until last week at Ae poploc lever wouldn't release well it would if i pushed the button
and flicked the lever not exactly the easiest thing to with one hand,so i've replaced the cables inner and outer still no joy not a massive problem just more of a niggle i do like the lock out for climbing
anyone know of a fix ?
Rubbish design IMO, got a Reba that intermittantly does it, tried lube, PTFE cables etc but it still does it from time to time.
Did you use a gear inner and brake outer, you should have?
Depending on the model you may be able to convert back to a fork mounted compression/lockout.
From what I can remember it's just a case of disconnecting (unhooking)the return spring which is located in the damper cartridge and replacing the compression knob, don't think it's a big job.
My 2012s went the same as predicted by my mechanic mate . I sent then to Merlin under warranty . They took a look and found the damper cartridge was pooped as well . SRAM had them back , replaced cartridge , new seals oil etc under warranty . I asked to leave the Poploc off which they did . Funny thing it's considered an upgrade ? Not cheap either .
Mine did the same, it's a piece of junk and I don't miss it at all
when I had one on old fork I got a crown top dial and followed the online PeterPoddy guide to swop it over - dead easy and the parts were about £20. was about 4 yrs ago mind
Take the top cap off, gunk etc gets under and causes it to stick. Give it a good cleanout and it'll be right as rain.
Cheers I'll take the top cap off the blue one with circlip? and give it a clean ...so it sounds like a common problem same old SRAM
