Reba foam 32mm foam...
[Closed] Reba foam 32mm foam rings
Morning.
Did my first lower leg service on weekend. The forks are Reba RL 140mm (2018 I guess).
I bought all the oil/grease/32mm foam rings before hand. All went well, apart from the foam rings are too high.
The ones I bought as replacement from TFT look about 10mm high, the ones that came out look about 4 or 5mm.
The wiper seals are fine for now, so just want to get away with swapping the (very) dirty old foam rings.
Anyone know where I can buy 32mm x 4mm foam rings alone?
Thanks.
Posted : 30/04/2019 11:32 am
are the foam rings damaged? if not, give them a clean in solvent cleaner and then re-lube them with either the fork oil or the right stuff which RS recommend and pop the old ones back in. I remember that the RS manual says they are re-usable if they are not damaged.
Posted : 30/04/2019 12:04 pm
I did try, but they're still really dirty! Rather just bin 'em and get some fresh ones in there.
Posted : 30/04/2019 12:25 pm
Are they the thin yellow ones? You can normally get a bagful off ebay for not much.
eg https://www.ebay.co.uk/i/401510293753?rt=nc&_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D20160908110712%26meid%3D797ae64ebb104e88ab09702c7f74f308%26pid%3D100677%26rk%3D5%26rkt%3D15%26mehot%3Dlo%26sd%3D392275250270%26itm%3D401510293753
Those are the type that used to go into my Rebas, may not work for you.
Posted : 30/04/2019 4:56 pm
