Reasons why I love ...
[Closed] Reasons why I love Shimano #1
Always been a fan of Shimano - BUT - 3 succesful warranty returns in the last 12 months !!!??
1. Saint rear mech - all pivits went baggy in about 5 rides.
2. Pair of XT M775 brake levers - seals failed, 12 month old, moderate use.
3. XT rear calliper - seal failed after 14 months moderate use.
Posted : 01/08/2011 1:01 pm
 DanW
In response to the original post- this is how to cover the gap left by removing the gear indicators (started as XT, polished, added an alu clamp bolt, custom alu barrel adjuster, carbon fibre section to cover hole where gear indicators used to be) 😀
Also reminds me of another reason why Shimano is so great... super reliable, no nonsense components that are easy to tune and lose weight without losing any of the original durability. Great stuff!
Posted : 01/08/2011 4:29 pm
A special mention to there spd range. I dont think in nearly 20 years of riding spd's i've ever had a set fail on me, cosmetically i've moved on but thats it.
Oh, and it would be great for them to bring out a bling bling carbon XTR seatpost, stem, bars and barends.
All hail shimano ( until di2 makes its way to mainstream mtb'ing and things go tits up in the scottish winter) 🙂
Posted : 01/08/2011 5:52 pm
So, now i have found a hot-bed of Shimano wheel bearing loving people can someone please post a link or some info outlining where I can get a WHOLE COMPLETE set of cup and cone bearings* for a Deore M525 front hub and M475 rear hub.
Thank You.
* thats the pressed in cup that sits in the hub as well as the cone shaped thingy that goes on last and takes up the slack.
Posted : 01/08/2011 6:11 pm
cheez0,
I am a shimano wheel loving person (except for their 20mm front hubs, they look nice but are rubbish).
If your 'cup' parts are knackered too then it's new entire hub time. 🙁 I have heard anecdotally on here of people pressing them out and replacing them but you caouldn't buy a new cup part anyway as its supposed to be non-user removable.
On the rear hub see if the left hand cup is knackered, if it isn't as ****ed as the rest of the hub and you want to keep the wheel built as it is, the cheapest way is just to buy a whole new hub and take everything off it (including freehub, which is a way to replace the drive side cup) and put it back onto the old hub. I did this to an lx hub a few years ago and it is still going strong 3 bikes later.
Posted : 01/08/2011 7:43 pm
[b]"Maybe you should learn to maintain your bike then. Cup and cone is a better more efficient solution, but tooling costs more hence only Campag and shimano still use it. "[/b]
BS...all the cheapo "bicycle shaped object" bicycles come with loose ball bearing hubs
nothing expensive, above producing cup and cone bicycle wheel hubs....
Posted : 01/08/2011 8:46 pm
Not if you produce them in huge quantities - maybe you should read what it is you're replying to though...
Posted : 01/08/2011 8:55 pm
The only reason its more efficient is because it has poorer seals
Rubbish - as has been pointed out, high end C&C hubs have better seals than typical cartridge bearings do (cartridge bearing seals are typically designed to keep out dust, not water). Meanwhile the larger balls in C&C hubs are the most significant factor in better efficiency - and also better resistance to contamination.
Posted : 01/08/2011 9:08 pm
Wow some people need to chill a bit on here.
BTW Why would you se anything other than Shimano?
Apart from my brakes which are Hayes, oops 😀
Posted : 01/08/2011 10:18 pm
aracer - and good cartridge bearings have better seals than any cup and cone bearing. Just by the very nature of the thing the cup and cone ones cannot be so close fitting and as soon as any play develops the seal will wear.
Posted : 01/08/2011 10:21 pm
...yep, its all gone quiet.
Proves Shimano are not quite as good as all that.
Not very good practice to have to throw away an expensive machined hub just for the sake of a 30p piece of steel.
Posted : 01/08/2011 10:22 pm
Name me a "good" cartridge bearing, the seal on which is designed to do something other than keep out dust. Bonus points if you can name me a hub which fits such bearings.
Posted : 01/08/2011 10:23 pm
 mrmo
The cartridge bearings i have seen in the hubs i have used, Hope and Campagnolo are no better sealed than the Shimano or Campagnolo Cup and Cone hubs i have used. The cup and cone could be tweaked, regreased and maintained. The cartridge bearing hubs, bearing wear you bin them, not vey environmentally friendly?
As for bicycle shaped objects, yes they use cup and cone, but because it is cheap to mass produce the hubs, QC is minimal so durability suffers.
Posted : 01/08/2011 10:28 pm
cheez0 - Member
http://www.jejamescycles.co.uk/shimano-m525-deore-item103844.html
http://www.on-one.co.uk/i/q/HUSHDEM475/shimano-deore-m475-rear-disc-hub-36h-6-bolt-fitting--black
Like I say I've never done the cup swap thing- never had to- but if it works, then here is your complete bearing kit, conveniently packaged in a hub 😉
Posted : 01/08/2011 10:50 pm
some stuff on seals in 2rs bearings - there is more to themthatn some of you realise - I took some apart that were 3 part
2RS seals marked LLU or LLB: 2RS literally means Two Rubber Seals and simply means that the bearing has these. There are many types of seals. On most other bearings 2RS means that the seal is made from rubber and has one sealing lip rubbing on any flat part of the inner race. Our seals are either LLU (usually the MAX type bearings) or[b] LLB (better for hubs).[/b]
LLU seals have 2 sealing lips on each seal which also fit into a matching groove on the inner race to make a type labrynth seal. LLU is a medium/high contact type seal. [b]The outer sealing lip repels dirt and water while the inner sealing lip retains the grease.[/b] When the bearing is first turned, you will notice some grease will come out of the seals. More on that later about “grease” but what this does is fill the chamber between these 2 sealing lips forming a “hydromatic seal” of grease.
[b]LLB seals have 2 sealing lips on each seal which also fit into a matching groove on the inner race to make a type labrynth seal.[/b] LLB is a low contact type seal. The outer sealing lip repels dirt and water while the inner sealing lip retains the grease.When the bearing is first turned, you will notice some grease will come out of the seals. More on that later about “grease” but what this does is fill the chamber between these 2 sealing lips forming a “hydromatic seal” of grease.
http://www.endurobearings.com/bicycle/tech/abec-3_tech.html
Posted : 01/08/2011 11:05 pm
Hey northwind, I see what you did there,
Can you get the hubs conveniently packaged with a ready assembled set of spokes and rim for the same price?
Posted : 01/08/2011 11:08 pm
To those folk questioning Shimano quality and durability, might I suggest that you work in a bike shop for a while and pay some attention to the relative numbers of repairs involving Shimano components to those of their competitors.
There is a very good reason that Hope make lots of spares.
Posted : 01/08/2011 11:11 pm
Lots of BS written about bike stuff. Enduro appear not to even understand what a labrynth (sic) seal is (either that or they're trying to baffle with BS).
Posted : 01/08/2011 11:13 pm
druidh - all the people on here reporting failed brake seals recently? Unrepairable callipers?
Posted : 01/08/2011 11:16 pm
TJ - "all" was 2 folk if I recall.
As I said above, if you're not in a position to weigh up the evidence, don't speculate based on the utterances of a handful of unhappy users.
Posted : 01/08/2011 11:23 pm
It was a lot more than two - and anyway I made no comment on the reliability of shimano. I made comment on the non repairablity - a different issue.
Posted : 01/08/2011 11:29 pm
I had an XT caliper seize up, which should have meant a £2 seal but meant a whole new caliper. Buuuut the thing is, I went out and got a cheap caliper for £20 or so, and it came with a set of new pads as well. Took out a seal and fitted it to the XTs.
So that's not so terrible in the end, it's not how it should be but I could live with it. The inevitable comparison with Hope is interesting for 2 reasons. One is that the Hope parts don't work out all that much cheaper when you take into account the £15 worth of pads- we're talking a few extra pounds.
And the other is that for equivalent-performance brakes, the Hopes cost enormously more in the first place. That pays for an [i]awful[/i] lot of replacement calipers.
So I guess it's just as well Formula have high performance low price brakes with full spares availability, so that you don't have to make that awkward choice 😉
Posted : 01/08/2011 11:37 pm
I'm with TJ!
Posted : 01/08/2011 11:40 pm
is it just that people with Hope stuff ride more or perhaps cant do maintenance to their bikes? Shimano folk are goos at maintenance as they have to adapt their stuff from new to suit 😉 The first point is serious BTW.
Mine have been faultless both sets.
Posted : 01/08/2011 11:50 pm
Its about the philosphy. shimano are ( like most japanese manufcturing) fantastic engineers especially production engineers. the aim is to get a product that is reliable out into the market at minimal cost. In order to do this it means clever production engineering to reduce the amount of machining needed.
Very little effort is given to easing maintainence or repairability you are intended to throw it away and replace it once it wears or needs repair. thus spares are often not available and repair are difficult to do.
European manufacturing tends to focus more on repairability and maintainence and spares availability so using stock sized parts for example less of a throwaway philosophy.
Posted : 02/08/2011 12:02 am
Yes, well, there you go, eh?
What?
Posted : 02/08/2011 12:13 am
Whatever happened to the guy in here that wanted to make/source seals for shimano calipers? (not that I have had one ever fail on the three sets in mrs j and my brakes, or 4 sets on other mates' bikes) (if you [i]are[/i] counting, tj 😉 )
Posted : 02/08/2011 9:02 am
TandemJeremy - Member
...I made no comment on the reliability of shimano. I made comment on the non repairablity - a different issue.
But the 2 are inseparable: the importance of non-repairability decreases as reliability increases.
Why can't you admit this?
Posted : 02/08/2011 9:06 am
When you can buy a decent hub for £20 who cares about repaiability, the time effor and energy to make it repairable and to actually repair it is pointless.
I dont know what kind of mileages people do on hear but i have a set of campag chorus hubs which are 18 years old and have never been stripped down and have do i would think about 5000 miles between me and my dad (who now uses the bike)
I used to always strip my old hubs when i was 15 and clean and re grease, for fun not because they needed it, i had the time because i didnt have a wife, kids and a life outside bikes, now i have all i want to do is ride.
****in chill about the hubs please.
p.s. Shimano is the best 😀
Posted : 02/08/2011 11:31 am
But is that common place? I seem to be getting 15 years+ out of my Shimano hubs. I've never had an axle seize on SPDs either.
Old school bearings rule!
Posted : 02/08/2011 11:40 am
There's cup and cone bearings and cup and cone bearings. You cannot seriously argue that the bearings in a £99 Halford's special are exactly that same as in your common or garden XT wheelset? The ball bearings and races will be made to much tighter tolerances for a start.
I run cartridge bearing hubs on my bikes, mainly out of vanity because I like the colour blue. I have no qualms with cup and cone hubs, indeed both the stepkids have them on their bikes and they're maintained on a shoestring but keep on going.
Posted : 02/08/2011 12:25 pm
I've got some old Shimano 600 road hubs on my winter commuter, probably 20 years old. They were used for 'cross for years by a well known rider, I then acquired them, and have totally abused them (being as they're on a winter road bike). I've probably done 5000 miles or so at a guess over 2 winters, and they're absolutely perfect, they've been jetwashed a couple of times and not much else. The cartridge bearings in my PowerTap have been replaced 3 times over one winter.
Admittedly the bearings in my DT front hub on the summer bike (which was my 'cross bike for a while and got used all year), have never been replaced and must've done at least 20000 miles. So... very inconclusive, but Shimano components are awesome, wouldn't go back to SRAM lightly, particularly Avid brakes vs the new Shimanos.
As for transplanting the cup out of a Shimano hub it's very doable, and an excellent way to totally rejunvenate your wheels, stonking value really when you consider you get a new skewer in the deal. Just turn the hub shell into a pen pot or something!
Posted : 02/08/2011 12:28 pm
And the other is that for equivalent-performance brakes, the Hopes cost enormously more in the first place. That pays for an awful lot of replacement calipers.
Yes I'm sure 11 quid is an enormous amount in Northwind land, doesn't buy you a whole lot of calipers though. 🙄
Do you live in some bizarre alternate reality? Formula brakes are hardly low price! Not conviced by the claims of high performance either having experienced some K24's...
Posted : 02/08/2011 1:04 pm
I think he forgot the smiley. The performance is actually very good though - I have R1s which work very well, and all reports I've seen suggest the reliability is better than the more common brands, but they were far from cheap, and I imagine I'll be getting any spares from ebay in the same way I got the brakes.
Posted : 02/08/2011 1:16 pm
Bullshine - cup and cone is victorian engineering with no place on a modern machine. Once the bearing wears the hub is scrap - fantastic
100% agree, I mean the hubs on the tourer ar 30 years old, in another 30 years when the races are worn out they'll be obsolete and I'll have to buy new hubs, shocking!
Posted : 02/08/2011 2:02 pm
pypdjl - Member
Pair of Oros for £130 euros delivered, with rotors, mounts and hose shortening kits, direct from Formula. In what [i]bizarre alternate reality[/i] is that not a low price for quality hydros?
Posted : 02/08/2011 7:54 pm
Yes well done, they are flogging some old stock off cheap, hardly makes formula brakes cheap in general.
Posted : 02/08/2011 8:27 pm
They've been that price for well over a year now, and plenty more to go, so it's a pretty steady alternative to paying more for less from Shimano.
Posted : 02/08/2011 8:35 pm
Page 2 / 2
