Rear Shock upgrade ...
[Closed] Rear Shock upgrade question
I`m looking to upgrade my rear shock
I`ve got a rear shock that is 190 x 50 it as no lock out or pro pedal
Can i fit a longer shock say a 200 x 50 and would it be okay?
my frame is 120 mm rear travel
Posted : 20/11/2011 8:50 pm
probably be ok. Depends on the frame design. Ive put a 215 on a pitch that was a 190 and thats great. raises the bb. what frame is it?
Posted : 20/11/2011 9:12 pm
Its a rockrider 9.1 frame
Posted : 20/11/2011 9:13 pm
Would make the angles slightly steeper and raise the BB, but not dramatically. Would be better to get one the same size if you can.
Posted : 20/11/2011 9:18 pm
Youve gotta have the 10mm space you will require. As sambob says try for the same size but a 200x50 should be ok.
Posted : 20/11/2011 9:23 pm
