Rear shock tight in...
[Closed] Rear shock tight in mount?
Just reinstalling the rear shock after servicing the fun bits. When I get anywhere near the specified torque at the front mount it gets really tight and the shock doesn't hang down, but is held up. I can't remember whether this was the case when I took it apart.
Should there be more freedom of pivotness than this?
It's a Rocket 275, if it's a specific issue
Posted : 12/07/2019 5:38 pm
Gut instinct, yes it should be able to move more than that. Certainly does on my fs.
Posted : 12/07/2019 10:28 pm
If it's a du Bush your using the there's plenty enough friction to hold a shock up. It would be normal. If you want it to run freely you need some sort of bearing in there, either a needle roller or bearing mount shock even better (but that's something that must be designed for up front)
Posted : 12/07/2019 11:13 pm
Thanks for the input. The shock doesn't pivot very much on compression anyway and was fairly easy to move by hand, can't imagine a great deal of wear will occur so long as I keep it greased.
Posted : 13/07/2019 4:09 pm
I'm sure I read somewhere that you don't grease du bushings? Might be wrong though.
Posted : 13/07/2019 6:27 pm
This I do know.Lol
You don't lube du bushings as said above.👍
Posted : 13/07/2019 8:20 pm
I had this on a new 2012 Orange5 frame, used theses to good effect.
Need a regular service in winter though
https://www.enduroforkseals.com/products/rear-suspension/shock-eyelet-bearing-kits/6mm-8mm-thru-bolts/NEEDLE-BEARING-22.20.html
Posted : 13/07/2019 9:20 pm
DU bushing? I don't think it is, it's brass or bronze or something. Unless that's what a DU bushing is, in which case I should probably get the iso alcohol out.
Posted : 14/07/2019 6:34 pm
You wont get much rotation at that front shock mount.. so needle bearings are pointless here.
I'd certainly explore needles on the swingarm end if you are a really light rider though or super sensitive to stiction.
tolerance is a factor here, even with the lowest friction bearings/bushings, you could still bind things up if your end reducers are being forced against the shock eyelet when tightening.
Posted : 14/07/2019 6:43 pm
I'm not light by any stretch. There's not a great deal of movement at the swingarm end either.
I'll try again getting in touch with Cotic to see what they say. Seems a bit tight, but not sure what's changed if anything.
Going Woody's again in a couple of weeks, that'll show up any faults ๐Ÿ™‚
Posted : 14/07/2019 7:50 pm
