rear shifting probl...
[Closed] rear shifting problems on the road bike advice please
the rear mech changes lovely up the cassette from smlest to biggest cogs, changing down it changes down fine for the first 4 cogs, then for the next 4 it needs 2 clicks to move down one and then an upshift to counteract the 2 downshifts. the last 2 shifts to use the 2 smallest cogs work fine. I thought at first it may be dirty cable but cleaned everything out and it releases the correct amount of cable for 6 of the 10 shifts
any suggestions is it likley to be the mide of the cassette is wearing out?
cheers
Posted : 29/03/2011 8:59 pm
recently had the same thing, fixed with a new cassette, chain and a tweaked mech hanger.
Posted : 29/03/2011 9:11 pm
Have you messed about with cable tension? Couple of turns of the barrel adjustor can make a difference.
Posted : 29/03/2011 10:10 pm
have you check hanger alignment? (with the correct tool)
Posted : 29/03/2011 10:14 pm
Is the chain properly lubricated?
Posted : 29/03/2011 10:26 pm
