Rear mech servicing...
[Closed] Rear mech servicing, who does it and what do you do?
In the past I have always given my rear mechs a strip down at least once a year. Give everything a good clean, grease jockey wheel bearings/bushes and try to get a bit of lube in the pivots and maybe lube threads of limit screws.
Current bike has Sram X01 mech that has had no attention for a year since new. Bike is in stand as forks/shock been away for service/tune and I'm not riding because of injury so thought I'd give everything a service.
Had a look at sram manual and all it says for maintenance is cleaning. Mech has a little dirt on it and jockey wheels have a bit of putoline build up but spin fine and smoothly. Is it worth a strip down, disturbing limit screws etc? What do you guys do?
Posted : 12/02/2021 7:54 pm
Rear mech servicing?
What's that then? I clean mine a few times per year.
Posted : 12/02/2021 8:01 pm
You can strip a SRAM mech down completely without much difficulty, taking the parallelogram apart and everything. You need to do this when the low quality plastic bushes fail and the mech gets stiff. I did it to my XX1 and to be honest it made no difference, once they're goosed they're goosed.
Posted : 12/02/2021 8:07 pm
I wouldn't call it a service, but I might put a drop of lubricant onto the hinges every now and then.
Posted : 12/02/2021 8:08 pm
Didn't know that @munrobiker always had shimano in the past. @scotroutes I have a lot of time on my hands at the moment 🙂
Posted : 12/02/2021 8:26 pm
I spray mine with WD40 or GT85 in the winter but that's just to help prevent it icing up.
Posted : 12/02/2021 8:29 pm
My servicing is pretty much replace it when it breaks! It might get a drop of lube when I remember
Posted : 12/02/2021 8:30 pm
Don't you just smash them on rocks before their first birthday? No need for an annual service! Got to take the positives from every situation.
Posted : 12/02/2021 9:31 pm
erm, it gets hosed off after any particularly filthy rides, and a bit of GT85 or wet-lube when I'm feeling tinkery. Honestly, I've never considered it to be a part that needs servicing up until recently seeing a GMBN video on "servicing your rear mech in real-time". After seeing that I might pop the clutch cover off every now and then and make sure it's not full of grit.
Posted : 12/02/2021 9:44 pm
Bit of oil on pivot points but I have always mainly concentrated on the jockey wheels to be honest.
Posted : 12/02/2021 9:52 pm
I’ve found mine gets really difficult to shift and I open up the clutch and take it apart to clean and regrease.
Posted : 12/02/2021 9:59 pm
Shimano ones aren't difficult to take apart and grease. Unsurprisingly they work better afterwards 😃. Also useful for making one working mech out of several broken ones 🙄.
Posted : 12/02/2021 10:35 pm
Change the jockey wheels when they look like ninja throwing stars and spray some lube at the pivots.
Thats about it really.
Posted : 12/02/2021 11:18 pm
I squidge a wee bit of lube near the jockey wheels. Sometimes, I squint at it from behind and if I decide something's bent I'll give it a quick push which does nothing.
Posted : 13/02/2021 1:27 am
Free off and grease top pivot off it seizes (only seen that on customers' bikes), jockey wheels might need work, that's it.
Posted : 13/02/2021 7:02 am
Well, I'm gonna go ahead and service as much of mine as possible. Told you I have time on my hands and it can only do good. Plus, I'm a tight arsed yorkshireman that likes things to last as long as poss.
Posted : 13/02/2021 12:24 pm
If it ain't broke, don't... Whoops, too late 🙃
Posted : 13/02/2021 12:37 pm
Thorough clean, jockey wheels off and cleaned, GT85 on all pivots and jockey wheels back in.
Hardly a service, just a clean.
Mine last for ages
Posted : 13/02/2021 12:56 pm
Sometimes the barrel adjuster seizes also
Posted : 13/02/2021 1:23 pm
Every few weeks or after a particularly muddy ride I'll clean and regrease the clutch after I had one seize a while back. Other than that it's just keep the jockey wheel bearings spinning freely and a quick squirt of GT85 on the pivots every other ride or so. Considering what a rear mech does and the abuse they take it's amazingly simple and easy to keep them running well!
Posted : 13/02/2021 1:24 pm
SRAM Jockey wheels need looking after. I've now replaced mine with BBB. I don't like how the metal caps do trap dirt between it and the rubber seal - had the seal damaged twice after really grubby rides. The BBB jockey's use a smaller 'spacer' rather than an end cap. If they are anything like Tacx jockey's they will last until the teeth wear out.
I just keep the mech clean and a squirt of GT85 or Muck Off protect and shine.
Posted : 13/02/2021 2:38 pm
I do mine once a year, videos online.
Posted : 13/02/2021 3:44 pm
Pretty sure Shimano recommend servicing the clutch on their derailleurs, Google Shimano clutch service, I've done it once and it took about 15 mins iirc and I occasionally remove and clean the jockey wheels
Posted : 13/02/2021 3:55 pm
I like to keep my main pivot clean & lubed
https://imgur.com/a/q6fC13A
Posted : 13/02/2021 4:15 pm
drip a bit of oil in the jockey wheels and pivots a couple of times a year. Thats all I do
Posted : 13/02/2021 4:21 pm
I had to buy a complete new (shimano 105) rear derailleur for wife's bike last week because the cable tension adjuster screw had seized.
So, from now on I WILL be servicing/lubing rear mech.
Posted : 13/02/2021 4:38 pm
I had to buy a complete new (shimano 105) rear derailleur for wife’s bike last week because the cable tension adjuster screw had seized.
Or you could have just fitted an inline cable adjuster 😉
Posted : 13/02/2021 5:04 pm
Regularly clean my rear mech with GT85 and a toothbrush then squirt silicone spray around the pivots and drip some oil in the outer cable at the shifter, I service the clutch and jockey wheels once a year.
Posted : 13/02/2021 6:33 pm
 feed
Every few weeks or after a particularly muddy ride I’ll clean and regrease the clutch after I had one seize a while back.
Also, learned the expensive way that taking the clutch cover of a shimano rear mech and greasing it will stop the spring from rusting solid killing the mech.
Apart from that, mine don't normally last long enough to require a service 🙁
Posted : 13/02/2021 9:21 pm
After wash and brush to clear old mud I just dismantle the jockey-wheels and clean them up fresh in and out. Reassemble. Wipe the mech down with oily rag and Roberto is your padre’s hermano...
Posted : 13/02/2021 9:39 pm
