Rear Maxle keeps co...
[Closed] Rear Maxle keeps coming loose (T129)
Mates bike (i'm HT only).
Whyte T129, the rear Maxle comes loose pretty much every ride. Been back to shop 3 times who cited "design fault", they sort it, only for it to reoccur, out of warranty. Appears to be the drive side threaded Maxle insert (female bit), it has a notch in it into which a tooth sits which is tightened down by a small hex bolt. At a guess this hex keeps loosening, allowing play to develop in the loosened axle. Thread lock considered, but apparently this part needs adjustment from time to time.
Anyone had this and/or know of a cure?
Ta
Posted : 06/07/2016 9:00 am
The small hex is there only to prevent losing the insert when you take out the wheel; the insert itself is held in place by the axle under normal operation.
The Maxle itself has an adjustment bolt in the center, is that correctly set?
Posted : 06/07/2016 9:06 am
Loose rear Maxles seem quite common on my mates' bikes.
Posted : 06/07/2016 9:25 am
otsdr - I hear you. I'll check next time I see him.
Posted : 06/07/2016 9:28 am
I have a G150 with a similar set up and it has never come loose. Are you sure he is doing the maxle up correctly? I'm struggling to think why it would ever loosen.
Posted : 06/07/2016 9:41 am
This is a common issue with Maxles, on one ride at Cannock the maxle on my Giant Reign unwound itself twice - to the point that the wheel came off.
Make sure there is no grease on the thread and threadlock.
Maxle ultimates are supposedly less prone to the issue.
Posted : 06/07/2016 10:01 am
Most certainly an issue with his maxle- as otsdr says, try tightening up the axle that runs through the center.
I've got a T129 and never had an issue with the rear axle.
Posted : 06/07/2016 10:07 am
The rear maxle on my old bike would do this unless it was done up b'stard tight.
New maxle on my t-129 hasn't skipped a beat. As said above make sure it is correctly adjusted and that he's correctly using the lever to lock it.
Posted : 06/07/2016 10:31 am
If the bike shop has looked at it and can't fix it I'm guessing it's faulty.
My friend has a dodgy front maxle on a pair of x fusion forks. The solution is a rubber band around the fork leg that holds it in place.
Try someone else's maxle if possible. See if it does the same? If that fixes it buy a different maxle.
Posted : 06/07/2016 5:42 pm
has a similar issue on my T130, the tooth doesn't sit into the notch enough allowing some rotation which shows its self as a loose maxle.I've thread locked the insert in place (only with the weak threadlock so I can get it back out if needed) and the problem is now gone.I think part of this is that I never tighten my maxle up really tight.
Posted : 06/07/2016 5:54 pm
