Rear Maxel Thread A...
[Closed] Rear Maxel Thread Alternatives
[#6538198]
Is there anything out there that is cheaper than a rear maxel with the same threaded end. Just tried a shimano e-thru on my kona 142x12mm dropouts and the thread is the wrong pitch.
Before shelling out a huge amount of money on the rockshox, option, i'm hoping there's a cheaper option out there?
Posted : 07/10/2014 11:09 pm
There's the DT Swiss RWS.
Don't know if it's the same thread but as I have a 135x12mm Maxle and a 142x12mm DT Swiss I can check tomorrow if the Dt Swiss fits in the Maxle dropout. I'll post back tomorrow.
Posted : 07/10/2014 11:45 pm
Betd do an intense axle that is the same thread pitch as maxles in 135mm version. Worth giving them a shout to check if there's a 142 version
Posted : 08/10/2014 12:08 am
As far as I can tell there are 3 142x12 'standards' for axles.
The Syntace X12 system which is what the DT RWS axle is.
Shimano 'E-thru'
SRAM Maxle
X12 has a finer thread pitch and a tapered cone on the QR end that locates the axle in the dropout.
Shimano's system is the same thread pitch as X12 but has a flat collar on the QR side and may or may not use a securing nut at the threaded end.
The Maxle thread is much coarser than the other 2, has a flat collar around the QR and no securing nut on the other end.
They all seem to perform pretty similarly but are all mutually incompatible (gotta love industry standards huh!). From my looking around at alternatives to the supplied axle for my Banshee Spitfire (Maxle standard) it seems the X12 system is currently the most popular with manufacturers. Unfortunately that means that the Maxle is the only real alternative axle that fits that particular standard I couldn't find any reliably available others. YMMV.
Posted : 08/10/2014 12:44 am
This is what i've discovered so far. Wish i'd have known this before shelling out for the kona dropouts.
Posted : 08/10/2014 9:35 am
 Sui
If it's any consolation 👿 i stuck a maxel on the back of my spitfire. The stock supplied one with retaining nut is good as it's secure, but an arse to take off at a moments notice should you need to. That said, i have found the maxel coming loose often
Posted : 08/10/2014 9:40 am
Yup I had to pump out £60 for a replacement Maxle on my Trek EX9. God knows why they are so expensive and why no one makes cheaper alternatives. Come on Superstar!!
Posted : 08/10/2014 9:51 am
my maxle lever snapped off (also 142 ona kona) as i was trying to change a tyre in freezing cold conditions in the alps
got a reverse components one from a shop in ADH for much less than maxle prices and works just as well
http://www.reverse-components.com/shop/en/Quick-release/-Attaches-Rapides
these guys are cheapest ive seen
http://www.brightlinecomponents.com/rear-axles---accessories..html
edit just seen brightline dont do a sram pitch thread, but if you contact the guy on facebook he may be able to sort you out
https://www.facebook.com/pages/Brightline-Components/1421072684770936?fref=ts
Posted : 08/10/2014 9:52 am
Posted : 08/10/2014 10:25 am
Yep, it's A about T.
Shimano ones are £22, fair enough and from i see, it's pretty much the same thing, likely better made yet without the thread pitch i need for the kona.
Surely there's a market for a cheap single maxel. Even one that comes in the longest length with extended threads and cut to fit marks?
Posted : 08/10/2014 3:17 pm
I can confirm that my RWS axle comes nowhere near fitting in my Maxle dropout. Finer & shorter thread on the RWS.
Posted : 08/10/2014 11:42 pm
