Rear hub bearings A...
[Closed] Rear hub bearings Arkose X 2017?
Hi can anyone tell me which bearings I need for the rear Novatec hub on a 2017 Arkose X. The rear wheel has suddenly developed a load of play which I assume is a cartridge bearing gone......the wheels have 700c Alexrims if that helps place them.
I've tried to trawl through the huge Arkose thread but that is impossible.
Thanks
Rob
Posted : 15/09/2020 9:40 am
JOYTECH D522GCC Cup and cone
According to my list
Posted : 15/09/2020 10:57 am
No they are definitely cartridge. The front hub are loose balls and the rear hub have a cartridge pressed in, on the non drive side at least
Posted : 15/09/2020 3:09 pm
Odd. 2017? The code in BOM and the spares sheet is for D522GCC and 'GCC' stands for Ground Cup and Cone. I don't remember any mid year changes but it's going back a few years now.
https://issuu.com/novatecwheels/docs/novatec_hubs_guide_2014/15 - lower right P15
Posted : 15/09/2020 4:28 pm
You should be able to pop the end caps off and see the code on the seal.
Posted : 15/09/2020 5:42 pm
Hub is a D482TSBT and on the non drive side there is a 6000RS
Cant check the other side as have busted rib and a chain whip is too much for me at the moment!
Cant find that hub number in the pdf..
Posted : 15/09/2020 6:13 pm
D482TSBT is sealed bearing spec, bearings are 6000RS both sides
https://www.novatecusa.net/product/d482tsbt-11s/
Posted : 15/09/2020 9:26 pm
Thanks Jameso. At least I can order some new ones to fit when I'm fit!
Posted : 15/09/2020 10:13 pm
