Hi,
Been a while since i setup a rear mech/new cassette combo.
Having a problem. Click up on the shifter and the chain stutters doesnt want to go up the block. Tighten the cable so it does go up but once it gets onto the next cog the cage on the mech due to cable tension is too far over and grinds agaisnt the next cog. Shifting back down isn't happening.... So loosen off the cable so its not grinding and im back to the problem i cant change up gear.
Ideas ?
Cables gritchy. Lube 'em.
It's not the cables - there moving freely with the older cassette and chain the shifting was absolutely spot on instant either way.
trial and error and swearing works for me or i do it
[url= http://www.parktool.com/repair/readhowto.asp?id=64 ]this way[/url]
Aye tried that, not getting far. It's no better still after another hours tinkering 👿
It's not the cables
Well that's me told.
But for the symptoms you describe, it's cable related IME.
Sorry i didnt mean to "tell" you or anything 😉 I just know it is not the cables. Old cassette and chain fitted it ran smooooooooth perfect.
New chain and new cassette and im damned if i can get it shifting proper.
