Really dumb questio...
[Closed] Really dumb question regarding dropper posts...
Just pulled the trigger on a dropper. Will I be ok keeping my qr seatclamp, or do I need a collar type clamp?
Posted : 25/11/2015 9:51 pm
No reason you can't keep your QR. I have a bolt on mine now, but only 'cos the QR one died.
Posted : 25/11/2015 9:53 pm
All mine also have a QR, I don't always want to have the seat only 150mm down (and sometimes I want a "very down" and "slightly down" rather than "up" and "down")
Posted : 25/11/2015 9:56 pm
Perfect. Ta.
Posted : 25/11/2015 10:02 pm
I'm really overly sensitive to saddle height and if I switch to different shoe sole thicknesses I do like to change the height. easier to change with the QR. Makes no difference probably but it would nag at me on climbs.
Posted : 25/11/2015 10:05 pm
Yip, on some very steep descents, I'll drop the 40mm I have as well as the dropper. Very rarely, but worth having the option IMO.
Posted : 25/11/2015 10:19 pm
When it's set it's set for me, 150mm of drop is enough and I like the right height feel when it's up. I swapped out the QR as it was needed for another bike.
Posted : 26/11/2015 1:53 am
I use bolt collars purely because it's easier to get the right tension - reverbs are a bit susceptible to having the right amount of torque on and it's easier to do that with an Allan key. Qr works fine though just use a bit of assembly paste on the post and don't close it super tight.
Posted : 26/11/2015 2:24 am
LEVs can be sensitive to clamping force as well - if its too tight they won't extend fully. The installation manual even warns against it:
Do not over torque your frame's seat collar as this may inhibit proper function of your seat post
They specify a clamp bolt torque of 6-7 Nm which isn't really much at all - the same as stem bolts. I'm pretty sure I used to do my QR ones up way more than that, but of course the problem is you can't measure the torque on a QR so you don't actually know how tight it is.
I guess the answer is - if the dropper sticks then loosen the QR off a bit until it doesn't ๐Ÿ™‚
Posted : 26/11/2015 8:32 am
A bolt up collar offers more security for your expensive dropper, if it's ever locked up outside anywhere.
Posted : 26/11/2015 8:52 am
I keep mine on the qr as if it were ever to fail mid ride I could lift it as high as I dare relatively easily.
Sort of a built in redundancy.
Posted : 26/11/2015 8:56 am
I go with bolt up for security.
Reverb provide a little collar in case of failure.
Posted : 26/11/2015 10:24 am
Just a piece of advice for all you peeps using bolt up collars - make sure you take out the dropper and grease it every once in a while, a stuck dropper is very hard to get out without damaging it.
Posted : 26/11/2015 10:47 am
Blueadvocate - Member
That's for limiting the height range of a reverb, not for jamming the post up in case of failure- probably not a good idea to ride about with it bearing weight.
Posted : 26/11/2015 11:30 am
