Real bike weights a...
[Closed] Real bike weights and UK when is toolight or heavy.....
re reading the weight weenies section, i just cannot credit some of the weights, increbibly light but when for UK trails, so riding up, down across things like lakes/peaks natural stuff does a weight become too light or too heavy?
And what are folks bikes 'real weights'?
Posted : 17/04/2013 9:41 am
 br
Real?
Large 140mm HT with pedals, guards, light brackets and proper-sized tyres - 25lbs
Need pictures:
[URL= http://i992.photobucket.com/albums/af45/bruce_nikki/13022012263.jp g" target="_blank">http://i992.photobucket.com/albums/af45/bruce_nikki/13022012263.jp g"/> [/IMG][/URL]
Posted : 17/04/2013 9:46 am
Oddly enough I weighed my bike on the bathroom scales for the first time since i've owned it as I was a bit curious. I adopted the (Me+Bike)-Me = Bike Weight approach.
So my Pace 405 with XC719 wheels, Rev Dual Airs, SLX gears and a bit of mud came in at 14.2kg (31.3lbs).
I'm fairly indifferent about the weight and can't say i've got a burning desire to reduce it. I think a rider skill upgrade is the most useful thing I can do...
Heckler as it left the uk 15-16kg heading to 14 now
Posted : 17/04/2013 9:49 am
To tell the truth, I was a bit disappointed that a bike that cost this much, with so much carbon and titanium, still weighs 10.8kg.
Even if I lost the bottle cages and bar ends and got a carbon seat post, I don't think I'd get it under 10kg, so, for me, that's about as light as you can get.
Posted : 17/04/2013 9:56 am
My XL Turner Sultan with 3x10 XT, Revs, 2.35 Hans Dampfs, Hope M4s, Pacenti TL28 and Reverb comes in at 32lb dead. Would like to get it closer to 30lbs so am changing 203/180 rotors for 183/160, braided hose for nylon, maybe a Nobby Nic on the back, lock ons for foam grips, maybe a carbon bar, might try tubeless. Can't think of anywhere else I'd be happy to compromise to save weight.
Posted : 17/04/2013 10:00 am
normal 'real' bike weights are in the 25 - 35lbs range depending on size, build, travel etc, obviously some will be outside that but as general rule.
I'll quite happily pedal a 35lb full susser around all day if there are some bigger downs to be had but > 35lbs and it starts to wear you down after more than 3 or 4 hours.
I also have a ~ 19lbs Carbon XC bike, and if I'm being totally honest, it's quite unpleasant on 'normal' rides, skittish and a bit of a handful, but its proper quick for when you're in a head down and pedal mood.
Rider makes far more difference than a few lbs of bike difference, but its always nicer to have lighter if durability and performance not compromised.
Posted : 17/04/2013 10:04 am
Just a shade over 23lb (10.5kg) for my Soul with SID's, 1x10 and no dropper.
Feels perfectly comfy and composed, but then im not that heavy and a bit of a mincer. More than enough bike for trail centers though imho.
Amedias: Rider makes far more difference than a few lbs of bike difference, but its always nicer to have lighter if durability and performance not compromised.
+1 quitting smoking made much more difference to my ride than upgrading from my rockhopper!
Posted : 17/04/2013 10:14 am
i with amedias...somewhere for me between 26lbs and 33lbs for UK all the light bikes I have owned either broke or inspired only skittish fear ......some of the heavy bikes have been great but 35lbs plus does drag.hence the medium ground of 26 to 33 still climb and descend
Yeti asr 7 32/33lbs
Posted : 17/04/2013 11:11 am
 mos
I weighed my XL 5 spot the other day & it's nearly 36lbs, which did come as a bit of a disappointment but it's a pretty heavy build with coil CCDB shock & coil pikes plus freeride inner tubes & a dropper post. Like amedias mentions above, it's a bit of a drag on longer rides but its absolute butter on the downs.
Posted : 17/04/2013 11:17 am
A smidgeon over 35lbs but with a fair bit of deore. M4s aren't light, and neither is an XT back wheel but its strong enough to hammer the downhills and compensate for my mistakes
It pedals ok uphill as long as I'm fit - I'm happy enough to lose a few pounds to make up for the bike being heavy. It does drag after 4hrs tho
Posted : 17/04/2013 11:27 am
My Giant Anthem X with XT groupset,Roval wheels,Racing Ralphs,carbon bars,etc comes in at 24.6lbs with pedals.
I would struggle to get it lighter without serious spending. Can`t imagine achieving a sub 24bs full suss bike that was still trail worthy unless you had very deep pockets.
Posted : 17/04/2013 11:48 am
My main bike which is 26.2 lbs with pedals (M Frame).....
Lapierre Pro Race529
[URL= http://i561.photobucket.com/albums/ss59/fatsweaty/20130415_103655_zps9d16b6d4.jp g" target="_blank">http://i561.photobucket.com/albums/ss59/fatsweaty/20130415_103655_zps9d16b6d4.jp g"/> [/IMG][/URL]
My play away bike is 30.7 lbs with pedals,the fork if changed would reduce it somewhat (L Frame).....
Marin East Peak 5.5
[URL= http://i561.photobucket.com/albums/ss59/fatsweaty/20130415_103345_zps953189fb.jp g" target="_blank">http://i561.photobucket.com/albums/ss59/fatsweaty/20130415_103345_zps953189fb.jp g"/> [/IMG][/URL]
I however weigh in at 93-95kg plus kit 😕
Posted : 17/04/2013 11:52 am
I think weight is given far too much focus when it comes to bikes. Unless you're seriously competing and chasing seconds, I really think people overplay its importance - it certainly doesn't define what is a good or bad bike on its own. I've gone from a low 20-odd lb XC hardtail to a circa 32lb full susser and pedalling, I can't really notice a significant difference. It certainly isn't preventing me from riding the terrain and distances I rode on my other bike. I have slowed down a bit on the steeper longer climbs, but i'm getting quicker as I'm getting fitter. The heavier bike rides much better too - which is probably largely related to its geometry rather than weight, but the extra weight has not significantly caused me any problems or detracted from the fun of riding. You're better off losing weight from you than your bike.
For me - for a good rugged all-rounder HT bike (rather than a lightweight XC racer), i'd be expecing 28 ish lb's, and for a good rugged full susser (Trail/All-Mountain 120 - 140mm travel) 28 - 33lb's. (My mate's Yeti 575 comes in at 28lb - weighed, my Covert 32lb on paper - not weighed). I wouldn't expect much weight saving with a carbon framed bike - carbon is not that much lighter than Al Alloy and a comparison with like for like bikes, the weight savings are miniscule, sometimes no weight saving at all.
Posted : 17/04/2013 12:07 pm
29er SS rigid 20lbs
29er HT 27lbs
29er FS 30lbs
All with droppers and pedals and a bit of gunk.
I used to think weight was about climbing, then I got the SS, put a dropper on and rode it down some singletrack, it's like riding a cloud.
Weight's about handling not efficiency I now think. Light is good.
Posted : 17/04/2013 12:09 pm
Tho I'm with Wobliscott re carbon, I don't think the relatively small saving, relative to the rest of the bike, is worth the extra cash.
Posted : 17/04/2013 12:11 pm
I've had hardtails from 26 1/2 to 32 lbs and FS from 30 to 33lb.
Notice the weight more when lifting bike over stiles, onto rack etc than when riding. Now at 27lb HT 32lb FS.
The FS is harder to pedal for any length of time uphill because of suspension bob and draggier rubber rather than the weight difference, but is much faster on rocky downs because of those things too.
I could get the HT lighter by losing the dropper and putting silly light rubber on it but that would spoil the enjoyment of riding it.
Chasing low weight seems pointless unless you are racing (and strava doesn't count as racing) 😆
Posted : 17/04/2013 12:46 pm
Some carbon frames weigh ~1lb less than their alloy equivalent, which other than wheels and forks, you can't achieve by swapping one single component (dropper post aside maybe).
All the little weight savings soon add up.
Posted : 17/04/2013 12:47 pm
Its one of those easy to measure stats, but in real life riding it matters little.
Geometry and tyre pressure matter more.
Racing round Bristol Bike Fest as fast as I could I shaved 10% off my lap times by going from my freeride style Covert (30+lbs) to a light weight HT Cotic (25ish lbs I think).
But that was me trying to race, I wouldnt normally ride around like that and try to keep up that pace.
Posted : 17/04/2013 1:17 pm
+1 amedias its rider weight thats more significant and cheaper to remove 🙂 What CX bike for Bike Fest?
Also having sensible components that allow you to hammer down makes you faster and rider weight and fitness is the major issue going up hill.
Imagine being 2 - 3 kg lighter and the speed that would provide - kinda puts removing the bottle cage in perspective
Posted : 17/04/2013 1:24 pm
Real life 25.5lb for a hardtail with 150mm fork, a 2.5 Minion DHF up front and a 2.25 Ardent at the back. Goes like stink up climbs of which there are lots, doesn't feel remotely fragile, but it's not a cheap bike. I find anything much over 28lb or so tends to feel a bit slow when you're booting it up short, steep climbs in particular. But it depends on how you ride.
You can do a lot with fast tyres, particularly on less steep stuff - I was looking at a review of the Cotic Rocket which got a lot of plaudits for 'not riding like a 30lb bike' and noticed in the pics at least, it looked like it had a Maxxis Ikon out back, which is a very fast rolling bit of rubber. I'm not saying it's the only reason it felt quick to those journos, but it sure as hell wouldn't have hurt.
Stick a pair of Super Tacky High Rollers on the same bike and I bet it wouldn't have felt quite so 'light'...
But anyway, I'd rather have grip and some durability rather than outright speed and fragility - my 22.5lb full sus race bike is an awful Peaks trail bike, feels breakable - but up to a point, usually an expensive one, you can have both.
Posted : 17/04/2013 1:27 pm
oh p.s and check your hydration pack do you really need that tool, pliers, saw, shovel spare everything? Some of the junk I have seen people put in their camelbak ..... Then chat about bike weight 😯 Wilderness maybe, events no take the risk.
Posted : 17/04/2013 1:28 pm
I think weight does matter when you compare a 32lb bike with one 10 lbs lighter.
a pound or 2 makes little real difference.
What makes a bike too light or too heavy is dependent on budget and what you want to do with it. Too heavy for a race XC machine is 25lbs, too light for a DH moster is 25lbs.
My Yeti is a smidge over 25lbs
[URL= http://i683.photobucket.com/albums/vv198/daverambo/Yeti2_zps66881ec9.jp g" target="_blank">http://i683.photobucket.com/albums/vv198/daverambo/Yeti2_zps66881ec9.jp g"/> [/IMG][/URL]
[URL= http://i683.photobucket.com/albums/vv198/daverambo/Yeti-Weight_zps5c2c57fa.jp g" target="_blank">http://i683.photobucket.com/albums/vv198/daverambo/Yeti-Weight_zps5c2c57fa.jp g"/> [/IMG][/URL]
Posted : 17/04/2013 1:32 pm
My XC race bike is annoyingly 10.05kg (with pedals, so i'm claiming a moral "under 10kg" rating 😉
my 150mm FS was 11.7kg from the factory but the addition of a dropper post, a different shock, larger front brake, and some flat pedals has seen this creep up to just under 13kg. Quite a diffence
The difference between the two is more to do with geometery and rider position than the weight, however, you can clearly feel the lower mass and CofG of the race bike when in transitional turns etc, much, much quicker to respond (to the point where i generally nearly fall off the first time i ride it after having been on the FS for a while 😉
Posted : 17/04/2013 1:39 pm
+1 BWD I like my 2.25 maxxis ardents they seem almost perfect for any situation and roll well. I find I just adjust tyre psi depending on conditions. Been meaning to try out DHF Minion
Posted : 17/04/2013 1:40 pm
My Evil Sov is about 31lbs with a KS Lev, Minion/HR, Burly wheels and SLX groupset.
It doesn't feel heavy when I ride it, and I always think a heavier bike will make me fitter. I do notice the difference as I also have a much upgraded Cube Acid with XT, Rebas, light wheels etc. But unless i'm doing an epic XC ride, it's the Sov I choose every time.
Posted : 17/04/2013 1:44 pm
Around 30 lbs for the trail bike and 40lbs for the downhill bike. Much heavier and it is not as fun, much lighter and it costs lots of money/I start breaking things.
Posted : 17/04/2013 2:35 pm
Genesis Alfine io id steel HT; weighed it at about 28lbs. A little portly, but you don't feel it. I could get it to sub 25 with rigid forks, singlespeed, some carbon bits and lighter wheels. That's light enough.
Posted : 17/04/2013 3:01 pm
my large 2013 Stumpy Evo is just under 14kg, i added superstar pedals and 780mm bars. I think thats alright for a large with 150mm travel and a dropper post. Prefer climbin on it that my same weight hard tail.
Posted : 17/04/2013 4:02 pm
My SB66C is 27lbs on the nose, with a Reverb & Fox 36 float on the front. I can't really save any more weight apart from silly stuff like inappropriate tyres & powercordz.
I do everything on it; xc, race enduro & DH with a tyre swap. Feels like a good weight to me.
Posted : 17/04/2013 4:19 pm
My Fatbike comes in a shade over 31lbs and that's with 4" tyres, 80mm rims and a double and bash driving a 9 speed cassette. It never feels too light.
Posted : 17/04/2013 6:43 pm
Just been out with the kitchen scales, Dh bike is 45lbs, ouch. Though it has big dual plys and dh tubes on at the min
Anthem is 26lbs which I'm pleasantly surprised by given that its on its way back towards being an Xc bike having been my dh/am/trail/Xc/pub bike for the last year.
I've never looked at the weight of a component when shopping
I add a further 190lbs to the equation ......
Posted : 17/04/2013 7:28 pm
28.2 Ilbs on my cheapo digital scales. Happy with that considering the reverb, tech m4s and the mostly xt build..
Edit- had taken the rear mudguard off though!
Posted : 17/04/2013 7:35 pm
I started the honc at the weekend with a Rocky Mountain vertex weighing in at under 22lbs, when I finished it was 28lbs with all the mud, brilliant really! 🙂
Posted : 17/04/2013 10:31 pm
Heaviest- well. Obviously there's no weight where it's suddenly too heavy, 32lbs is fine but 32.1 isn't? Nah. Also different bikes carry their weight differently. I reckon once they hit mid-30s they start to be a bit too much of a lump, it takes quite a lot to balance that.
Lightest- I got my Soda down to sub-20lbs, largely by taking bits away entirely. And to be honest, it's a handful. Great fun but there's many times when a heavier bike is easier to ride, it just takes so little to move it- a little rock can kick it aside, and a messy pedalstroke causes it more bother. Was riding it at the weekend and went to pedal up a rock step, accidentally wheelied without expecting it. Stuff like that. When it was a few lbs heavier it needed less thought to ride.
(this isn't a criticism, it's all as intended, but it's definitely past the point where lighter = better.)
Posted : 17/04/2013 10:37 pm
Nice Yeti althepal. Was tempted by the SB66 but it was just too much. Building a G Spot instead. Will weight more than the current stiffee lord have mercy on my soul...
Posted : 17/04/2013 11:22 pm
What's the score with people weighing your bikes in Kg...... are you wannabe Germans or something??
What's wrong with lbs ??
Posted : 17/04/2013 11:40 pm
SIR.9 comes up at 22lb. Could go lighter, Niner steel forks probably +0.5lb over the carbons, wheels are Surly SS hubs on TN719 with 2.35 (tubed) Ralphs so a set of Pro2's on Stans & tubeless might save 1lb. M647's probably +0.25lb on something lighter. Before the Niner I had the same kit on a 29er Inbred, & it felt lots heavier. Not badly so, but the Niner has a livlier feel to it.
FS Ventana El-Ciclon is exactly 30lb. Not exactly built light so could shave 2lb easy enough. Don't ride it enough to warrant it though.
Posted : 17/04/2013 11:44 pm
Frankers, I choose whichever unit makes it sound lighter. Sub-10kg, or 22lbs?
Posted : 17/04/2013 11:45 pm
I'm in Kg as I live in a metric country (Oz) and tbh it's a much better scale. Especially as everything else is listed in Kg, 100g makes a Kg and I was born in the 70's. I can still multiply and divide by 2.2 if required but CBA
Posted : 17/04/2013 11:49 pm
 grum
I would guess mine is around 33lbs but I have no idea really. It's a Pitch with 36 vans, dhx5 and a reverb. Feels awesome and I don't mind riding/pushing it up almost any hill including some big uns like Ben Lomond and Helvellyn. Mostly ride in the Lakes and do the odd uplift day/trips to Europe in summer.
I never usually ride more than 4-5 hours though and I wonder if I would on a lighter bike.
Posted : 17/04/2013 11:51 pm
About 9.8kg as pictured - including pedals, but not the seatpack - has had a few changes since and got a little heavier, but should still be <10kg. Not what you'd want for throwing down Fort Bill, but perfectly capable on normal trails. There are a few on here with lighter sussers though.
Oh, and I've never wished it was heavier - have done events which involve significant amounts of bike carrying, and for that a lighter bike really does make a difference.
Metric is a much more sensible system to use for measuring stuff, granddad.
Posted : 17/04/2013 11:52 pm
My Pitch is 32lb, wouldn't want it heavier but the geometry is more of a hindrance uphill than the weight.
I've ridden <25lb FS bikes and they're awesome, well built bikes don't feel fragile, but I couldn't afford to get the Pitch that light!
Mine got to 19.7lbs IIRC (real weight, on my scales at least!) by fitting a Furious Fred:
It's since got about 0.5lbs heavier - a better front rotor; I found the KCNC a bit lacking in power. I generally use larger tyres now; tend to go for 2.25" rather than 2.1" Schwalbes now. I changed the I-Links to normal Shimano cable, although I've got some Quaxar stuff to try that is really light, hopefully will last well!
I love it frankly. I've got two sets of wheels, but prefer how it rides with the lighter ones, the heavier (which are still DT240s on Alpines, so it's relative) ones just make it seem a bit sluggish.
I don't ride too many rocky places, done Afan and Brechfa (on the 1246g wheels) and Haldon and Dalby and various other places on it with no ill effects though! It's never going to really excel on technical rocky sections, but then neither do I frankly!
Posted : 17/04/2013 11:58 pm
My main bike is a '98 steel XL Rockhopper. It has had everything changed over the years except the frame and cranks and comes in at 13.6kg (30lb). Not bad for a 20.5" steel framer...
Posted : 17/05/2013 10:14 am
[URL= http://i6.photobucket.com/albums/y250/wilk2032/17.jp g" target="_blank">http://i6.photobucket.com/albums/y250/wilk2032/17.jp g"/> [/IMG][/URL]
I got my whippet down to this although there's a question over the accuracy of the scales. This was for the bike built up as below
[URL= http://i6.photobucket.com/albums/y250/wilk2032/whippetreynolds.jp g" target="_blank">http://i6.photobucket.com/albums/y250/wilk2032/whippetreynolds.jp g"/> [/IMG][/URL]
Loved riding it, took it to Lee Quarry and used it on the pump track, did trail centres and raced it (badly) at the nationals.
Posted : 17/05/2013 10:40 am
Within limits, there must be a relationship between rider weight and bike weight?
Aside from buying technological advantage (i.e. carbon wheels) like as not, there is a relationship between stiffness, strength and weight.
I'm 91kg, not the heaviest, but some of the light bikes here would behave like a spastic bambi under me, because they're going to flex much more than with a 65kg racer boy.
I'm never going to get a 19lb bike to feel great under me in rough terrain.
Posted : 17/05/2013 10:47 am
My scales are very cheap (2.99 from the petrol station) and therefore can't be garaunteed to be accurate but for my large ragley Blue Pig with 150mm rev's on front it cam in at 11.3kg (has a reverb as well).
I think that it might be a bit higher looking at the comparatives but tbh I'm 125 kilos so therefore i could probably go to the toilet and lose a whole chunk of the difference.
Posted : 17/05/2013 10:49 am
Personally I like as light a bike as possible. Carrying it over stiles, putting it in the boot, hanging it on the wall in the garage, turning it up side down to fix a puncture all much more pleasant with a light bike.
Posted : 17/05/2013 10:52 am
I disagree - I was a similar weight to you and the only issues I ever had were forks flexing a lot. Specifically SIDS which were then swapped for Magura's which cured the issue. The only other issue I had were the Reynolds wheels which would frequently snap spokes but this was down to the spoke themselves (those rubbish super lightweight ones which I can't remember the name of) and the rim never went out of true.
I wouldn't suggest taking it to a DH track, but I had no issues hitting fairly rough rock gardens on mine and due to the lack of weight, jumping it was lovely.
I think if you're happy to run 1x10, not have a dropper post and run some decent light'ish wheels you can easily get bikes down to a decent weight. I'd rather have a light bike than a dropper post/granny ring/big tyres but thats just me.
Ohh and I lied in my post above. That weight was with a set of Storck carbon forks in, not the Maggies. think it was just over 18lbs with sus
37lbs Giant Reign X with coil Lyriks and a coil Roco R on the back. Can pedal it up and down anything, although I do have legs like tree trunks
Posted : 17/05/2013 10:54 am
People get too hung up on frame weight, doesn't make much difference at all.
Posted : 17/05/2013 10:59 am
Maybe flange, its entirely subjective, which is of course the problem.
I learned recently how variable riding skills and styles are, despite the 'talk' and equipment on display. Your 'barrelling through rock gardens' could be my 'tootling over a couple of rocks' or vice versa.
You have kind of proved my point by mentioning your broken spokes too - they are,after all a very integral part of the wheel.
The lightest I ever managed that I was comfortable with was a 456ti, rebas and crests, run as a single speed. It weighed 22.3lbs, but the crests couldn't take it, even with big tyres, so I ended up with arches and a bike that weighed 22.5lbs instead.
Posted : 17/05/2013 11:14 am
My Kona Explosif 650b was 26.8 lbs stock- I took some weight off with the pedals, stem and went tubless on the front. Then added a chunk of weight by adding the new bars and a dropped post. Not sure what it weighs now but I was happy enough riding Swinley and the Ridgeway all day. More heavy than I'm used to but once riding you dont notice. I have noticed that the rear wheel isn't as easy to kick out because the back end is heavy- not sure if that is down to the dropouts or bigger cassette !?
Posted : 17/05/2013 11:29 am
Absolutely - and with everything there are compromises. When I had the rigid Storck fork in it was at its lightest. I did a 2 hour xc race in Suffolk (so flat singletrack) and I couldn't open my hands properly for a few days afterwards. The course was dry, for the most part smooth with a few rooty bits thrown in but in a quest for light weight I decided against plugging in the sus fork. When I took the bike to Lee I was fully expecting something to break with the way I was riding it but to my surprise it didn't.
The spokes in the Reynolds are not something I would have used had I not bought the wheels second hand and I ended up rebuilding the wheel with something more appropriate. After that they were flawless and not noticeably heavier.
Njee's bike is probably a better example. Full sus so you could pretty much ride it anywhere but bloody light too. However I've seen Nick (:stalker:) and he weighs about as much as my left leg hence maybe why he hasn't snapped it yet.
I think if you're willing to accept that light bits will break at some point and probably sooner than sturdier parts then it isn't an issue. Light, cheap, strong - pick two...
Posted : 17/05/2013 11:31 am
**waves**
I definitely agree with Scienceofficer's point, I don't pretend to be any good technically, and I don't really garner any pleasure from really technical riding, so I'm happy having a bike that doesn't excel at that sort of thing. I do really enjoy fast flowing singletrack, and love riding in the Surrey Hills, and find my bike fantastic for that.
Every now and again I think some more travel would be good, but I certainly don't wish it was heavier. I can imagine that heavier riders probably wouldn't enjoy it - since I've not been riding much the last 6 months I've gone to about 75kg, and I do notice my Podiums flexing when cornering hard, I'd fully expect someone of 100kg+ to find the whole thing noodly and horrible, but I certainly don't.
Technology has changed so much, 10 years ago I rode a Trek carbon hardtail with 28mm SID Carbons, v-brakes, Crossmax, full XTR etc, and it was still 2.5lbs heavier than my Top Fuel.
Posted : 17/05/2013 11:37 am
Whilst I've never worried a lot about weight, its always nicer to have a lighter bike.
However given im 16st (100kg) in the 'suit. Im more concerned about strength and reliability. Psychologically im happy knowing that things like bars etc aren't going bend / snap when im riding. Having had a set of cheap bars snap in the '90's its not a nice experience hitting the grass at 25mph (20 yards further on it was rocks 😯 )
Posted : 17/05/2013 11:48 am
27lb Gyro – but tbh the Wheels required hold it back a bit. Fine for covering ground but if you try to unleash it a bit on the descents it pushes back. So I'd say that's too light in this case…
However, I normally run the All Mountain version of the wheels with a Hans Dampf and a Nobby Nic, plus a dropper. Much more inkeeping with the whole bike and very, very fun. 29lb dead.
Those are real weights, verified on two sets of hanging scales (one of which are Park Tool) and with XT SPDs on.
Posted : 17/05/2013 12:00 pm
I've found that you really need to have a better class of wheel on 29ers - I suspect its the extra size allowing more flex. Your Gyro is pretty similar to my Sultan, which comes in at 29.8lbs until I bashed a KS lev on it anyway.
Posted : 17/05/2013 12:09 pm
Absolutely, and the American Classic All Mountains are mind blowingly good for this. 1750g and I've done some tame-ish DH tracks on them.
The race versions are good, but they're 1450g and it's a 120mm FS with an eye on hitting things hard – it's not there's anything wrong with them, they're just not a match for the bike 🙂
Posted : 17/05/2013 12:13 pm
I have a set of Sun Ringle Black flag Pros on mine - same weight as your AC's Pretty much spot on for it, I've just completed a week in Spain on pretty rocky stuff and the bike was superb all round.
Some of the hair-pins were so steep and tight that I folded the tyre completely over (although the bead held) so I'm thinking about getting something a bit wider to stabilise the tyre in those conditions. Most things wider seem to come with a bit of a weight penalty though.
Posted : 17/05/2013 12:20 pm
I find the snakeskin versions of the Schwalbes make a big difference in terms of roll over, but I've not ridden spanish haripins 😛
The Hans Dampf is bonkers hard and very good – the weight is very fair all things considered (930g verified). Doesn't fit in the back though so a snakeskin 2.25 Nobby Nic has done an admirable job as rear gunner.
Posted : 17/05/2013 12:29 pm
Yes, I seem to have (temporarily at least) settled on schwalbe snakeskin tyres - they seem to have the right balance of weight and toughness without being dual ply heavy. I managed to roll over my Hans dampf twice, so it wasn't too bad really.
Luckily, on the turner a Hans will fit in the rear, although I more often run a racing Ralph locally. Good weight and very capable - more capable than it looks.
Posted : 17/05/2013 12:38 pm
