rapid rise, will it...
[Closed] rapid rise, will it break my brain?
Is Shimano's Rapid rise dead in the water? It appears that a RR mech is cheaper than a standard version but I've a couple of questions.
Will it melt my brain if I use it with a set of standard shifters and reverse the polarity as it were?
Posted : 10/10/2012 8:11 pm
Use RR on all my geared bikes. Only time I had problems was when I had some one way and some the other.
With multi shift shifters it makes more sense to me to have them working RR than not, tbh.
Posted : 10/10/2012 8:13 pm
I usually service a mate of mine's bike for him, but he's been told I'm never doing the gears again unless he replaces the rapid rise mech. It left me a broken man ๐Ÿ™
Posted : 10/10/2012 8:16 pm
What wwaswas said.
Posted : 10/10/2012 8:18 pm
Park tool site explains differences in gear setup technique.
Posted : 10/10/2012 8:19 pm
I had one on one of my bikes and normal on the other bike. Was forever shifting in the wrong direction... have aligned both bikes to normal rise now!
Posted : 10/10/2012 8:24 pm
A must with flippy shifters.
I like.
Posted : 10/10/2012 8:49 pm
Used RR for a few years and actually preferred it to standard. Switched back eventually though as I bought a new bike and forgot to ask for RR - one bike RR and the other normal was too much for me.
Posted : 10/10/2012 8:58 pm
Takes me a couple of shifts each ride to switch between the two systems in my head, but I actually prefer RR.
Posted : 10/10/2012 9:00 pm
I much prefer normal rise as you can slam 3-4 gears down in one movement if you hit a big hill suddenly rather than 4 clicks.
Posted : 10/10/2012 9:20 pm
if all your bikes are not the same then yes your brain will melt !
Posted : 10/10/2012 9:42 pm
I don't think RR will continue as I believe it doesn't work with shadow mechs
I have it on my road bike (xtr mech) - seems more intuitive to me that the sti big lever makes a higher gear on both sides. I suppose the same "feeling" may be true on mtbs but I use either single ring at the front or else a LHS gripshift anyway, so irrelevant.
Posted : 10/10/2012 9:47 pm
