OK, I have spoken to my local bike shop and the part I am looking for for my cranks is out of stock and has a wait time of 4-5 weeks! So any turbine owners (or Deus/ride) could you please help! I need the measurements (outer/inner diameters and thickness) of the main crank bolt washer.
You can see the spacer in the above link. If anyone can help with this then I can try to find a match or get a local machine shop to make one.
Thanks in advance,
John
It .seems silverfish have a good few of them in stock might be worth a call to them yourself.
http://www.silverfish-uk.com/Brand/8917/Category/9134/Chainsets
Went to look for you and have taken the drive side crank off but can't see how to get central puller component out of the spider. It certainly doesn't drop out is just spins round.
Thanks Batman, alas this is what I need though and oit of stock. The local shop spoke to them earlier but might be worth a call to them myself.
http://www.silverfish-uk.com/ProductDetail/8917/9144/Bolt-Puller-Cap-EXI-Type-M15
Bruce,
Have you got the standard 4 arm Turbine or the cinch?
John
[url= https://activesport.co/Race-Face-Bolt-EXI-Type-MM15 ]Activesport[/url] ?
I just found them myself! I will give them a call tomorrow to see if they really have it in stock. Thanks.
John
You can just buy the ride one and use either the whole bolt or the washer.... I think the fit is the same (99%)
That's the one Bruce! You need to remove the end cap with a 10mm Allen key and then you can take the bolt with it's washer (don't lose it!) out.
John
You are right Ben, it's the same as a few of the cranks and they use the same spare part. I tried active sport and they are out as well. I phoned silverfish to see if they might have a spare from the workshop that I could blag but no joy. 4-5 weeks seems crazy!
John
I probably have stock but won't be back at hq until the weekend.
Sorry I also meant ride use a different bolt, no extractor cap - so different part number.
Out of interest, what happened to your original one? I ask because my Race Face Aeffect crank came loose last weekend and I was wondering if it's common problem. [Remembers he still needs to add threadlock to the bolt]
V8-no idea! I'm usually very careful taking stuff apart but stripped it all out to service it then put it back together and noticed that the bolt went in much further than before. Took it apart and realised the washer was gone. I have done some tidying in the cellar recently so am worried that it has been swept away. I can't find it anywhere which is really annoying me! I stripped the whole bike apart for a bit if a clen so it was apart for a few days as stuff gor cleaned individually and reassembled.
John
Where are you based John?
I'm in Exeter
John
I can pick up one from my spare set of Deus tomorrow and post out. You then post it back ASAP when your new one arrives?
PM me if you want to take me up on that.
This thread. Right here. Is why I love STW.
Even with the strong opinions on here :-D...
[b]Best. Bike. Forum. Ever.[/b]
In my opinion anyway.**
** Your experience may vary from mine and apologies for any grammatical mistakes or incorrect assumptions made.
๐ ๐
Thank Jam but Bruce has beat you to it! Bruce, thank you! I have had a word with a local Engineering workshop and they are going to knock one up for me. I'll give them the sizes.
Thanks for the help guys, really appreciated.
John
Just picked up a freshly machined stainless steel one for a couple of quid and some Haribo. Anyone in need of similar bits, the guys at SB engineering in Exeter were awesome.
Thanks for the help,
John
No worries! Glad it is all sorted.
Glad to have helped, I hope the pics were good enough.
They were spot on mate.
John
