I have a 135degree pipe and a 90degree pipe.
Which way around do they go - i.e. 90 front 135 rear?
Posted : 12/06/2012 1:48 pm
Whatever gives you the best cable routing. If you run RH front brake then the 135deg pipe is probably best off there. I got hold of 2 90deg pipes as I run a LH front so this gives a much better, smoother route. I've never come across a situation where a 135deg pipe is needed on the rear. HTH.
Posted : 12/06/2012 1:55 pm
