Quick Sealant Check...
[Closed] Quick Sealant Check?
 bubs
One of my bikes hasn't been used since October and the tyres were originally fitted and filled in March. Given I'm lazy and the tyres were a real faff to fit originally is there a quick check to see if the sealant is still OK? When I spin the wheels there is no discernible wobble or weighting issue.
Stans in Specialized Bliss Ready tyres on DT Swiss presealed rims if it makes a difference?
Posted : 23/01/2022 11:37 am
I recently discovered syringes with long blunt tips, like this
Makes it a doddle. Remove valve core, position wheel with valve at the bottom so sealant collects there. Insert syringe into tyre through valve, suck out old selant - if there's plenty and it still looks like sealant re-inject it, if not replace / top up.
Much less messy for first-fill as well, so install "dry" then inject through the valve hole once you're sure the tyre is seated.
I got a pack similar to these but in larger sizes (up to 100ml) https://www.amazon.co.uk/Shintop-Syringes-Dispensing-Experiments-Industrial/dp/B07HMQM7LV/ref=sr_1_10?crid=3KEB38KX6SEKQ&keywords=syringe&qid=1642939546&sprefix=syringe+%2Caps%2C75&sr=8-10
edit - also good for bleeding brakes, injecting oil into forks, getting grease into bearings etc etc
Posted : 23/01/2022 12:09 pm
You can normally hear the sealant sloshing around when spinning/shaking the wheel.
Posted : 23/01/2022 12:13 pm
Yep, if you can hear it sloshing when spun you're all good. If not then top it up.
Posted : 23/01/2022 10:24 pm
i use the dipstick method. valve core out and plastic dip stick (coffee stirrer) to see if its still wet.
Posted : 24/01/2022 9:10 am
Dunno, seems fairly sensible to me.
(Sorry)
Posted : 24/01/2022 11:37 am
