Quick Rotor Size Qu...
[Closed] Quick Rotor Size Question
Can I run a 185mm hope rotor with a 180mm shimano front brake set-up?
Would adding a couple of washers between the caliper and mount be acceptable?
Posted : 25/04/2010 8:18 pm
I hope so, I did the same with the wife's bike. Hope 165 rotor on the rear with Avid Juicy 5s and some washers to space it out. She's not died yet!
Posted : 25/04/2010 8:19 pm
Aren't avid 183mm though?
Hence a bit closer to the fit?
Posted : 25/04/2010 8:21 pm
Yep. Only need 2.5mm of washers.
Posted : 25/04/2010 8:22 pm
Nice
Posted : 25/04/2010 8:23 pm
Due the angles involved, it will take more washers than you think but a bit of trial and error will get you there.
Posted : 25/04/2010 8:34 pm
