Quick question - go...
[Closed] Quick question - going tubeless - schwalbe RRalph / RRon
 DT78
Quick question before I press 'buy' on these tyres - am I right in thinking if I'm using a conversion kit (joes) I don't actually need to buy the heavier more expensive UST versions? Will it just mean it's a bit harder to seal?
DT swiss 4.2 rim...
Posted : 17/04/2010 9:39 pm
 ojom
you should be fine but don't cry if it doesn't work properly type idea.
Posted : 17/04/2010 9:41 pm
Ask trailrat what he thinks about either of these Schwalbe UST tyres... my ears are still ringing from his expletives last year!
Posted : 17/04/2010 9:42 pm
 DT78
Hmmm I reckon the weight & cash saving should be worth the extra faff...
Wonder what hindsight will tell me ๐Ÿ™‚
Posted : 17/04/2010 9:52 pm
i run standard evo rons and ralphs tubeless. i will be getting the ust ones next time as the standard ones are a bit too fragile for the routes i ride lots of flinty gravel. i've had a few cuts which have resulted in me being covered in latex [nice].
Posted : 17/04/2010 9:53 pm
 br
it'll work, just might take some effort - you've access to a compressor?
Posted : 17/04/2010 10:24 pm
 DT78
Tyres will mainly be used on the hardtail for XC races down south so woody/rooty stuff so should be ok
Don't have a compressor but have a few co2 inflators, if that doesn't work was going to take them to the local garage
Posted : 17/04/2010 10:30 pm
[url= http://www.justridingalong.co.uk/content.php?pid=529&jrasid=87c2798f7a5dee242c723f384e1df3b2 ]Info on tubeless and all the stuff to do it[/url]
[url= http://www.tubelesswheels.com/fast.html ]ghetto tubeless[/url]
Posted : 17/04/2010 11:05 pm
 hh45
Can't comment on DT rinms aspect but i had RR s on Olympic rms last summer and worked fine with yellow rim tape and lots of JRA wheel milk. The video on the Stans website is very useful - wish I'd seen it earlier in my tubeless life.
Obviously non UST RRs are v thin but as you say, in the south it should be Ok if you avoid flints (so thats the whole of the south downs!). I ran mine at trans wales, chedder, D2D etc with no punctures.
Posted : 17/04/2010 11:12 pm
I find Schwalbe work really well converted with Stans, they're not the best for really rocky areas though, particularly Rons/Freds/Dans with the ligther carcass. For down here though, Rons are spot on, very good in the loam.
Posted : 17/04/2010 11:52 pm
