Quick pro2 question...
[Closed] Quick pro2 question?
Can I convert my rear hope pro2, currently a 135mm, to 150mm with 12mm bolt thru?
Posted : 09/08/2010 3:51 pm
no - not unless you have access to a lathe
Posted : 09/08/2010 3:55 pm
Nope - your disc would be out of line with just spacers as the hub on the 150mm is wider ๐Ÿ™‚
Posted : 09/08/2010 4:04 pm
you used to be able to buy spacers for your caliper and axel to keep everything in line , just had to redish your wheel to suit - mr big racing made them (in his garage)
used to have one of their frames back int day !
Posted : 09/08/2010 4:06 pm
nevermind, thanks for the quick replys... plan b it is then
Posted : 09/08/2010 4:12 pm
