quick - front mech ...
[Closed] quick - front mech compatibility question
[#2725912]
genesis latitude frame, bottom pull front mech required.
this;
or this;
CRC descriptions have left me confused tonight (am very tired!). but i think the top one is the one required...
yes? no?
Posted : 06/05/2011 11:21 pm
Either, look for "Dual Pull design for use with top or bottom cable routing" in the description
Posted : 06/05/2011 11:38 pm
i did, and the bottom one said dual pull, but it also said 'for top pull frame designes' - so i got confuddled.
so if they both work with both pulls, whats the point in having both types? and which should my friend get for her latitude?
Posted : 06/05/2011 11:41 pm
Clamp placement.The first one is 'conventional' the second is 'top swing'.O full sus designs the main pivot placement affects where you can clamp it to the seat tube i.e Orange 5 needs a topswing but yeti 575 needs a conventional.Either will fit the genesis (bottle boss issues not withstanding!).
Posted : 06/05/2011 11:48 pm
oh god... ok. i'll collate all i've found out and send her a message...
Posted : 06/05/2011 11:54 pm
I have a top swing on my Genesis Altitude (last years Latitude).
Posted : 07/05/2011 12:46 am
If either will fit your particular frame, get the conventional swing. The pivotal need to last longer and the arc keeps a little closer to the rings for better shifting.
Posted : 07/05/2011 7:33 am
