Hayes Nine Bleeding
[Closed] Hayes Nine Bleeding
[#2725899]
Got the bleed kit. Not got the instructions.
Help please!!!
Posted : 06/05/2011 11:05 pm
 wors
Look on the hayes website. Full instructions there.
Posted : 06/05/2011 11:07 pm
Slightly different method that takes the slack out of the lever [url=
I'd not recommend doing it with the pads in like he says, unless you have an old set you want to use. Just judge it by the pistons moving.
Posted : 06/05/2011 11:43 pm
Pressurising these brakes before locking off the bleed screw is a bit of a recipe for popping the m/c plug when the brakes get hot and the fluid expands. A similar effect can be had by servicing the caliper(full strip and clean, and re-assembly with silicone grease on the seals and pistons), long lever travel on a properly bled brake is usually down to sticky pistons not self adjusting properly.
Posted : 07/05/2011 7:51 am
