Quick compatibility...
[Closed] Quick compatibility question
I want to upgrade my tranny to 11-speed XT M8000. 2 issues:
1 - I have those brakes http://www.chainreactioncycles.com/shimano-slx-m675-disc-brake-set/rp-prod115147. Will the XT M8000 shifter be compatible for a single clamp ? If so, do I need to order I-spec B or I-spec II ?
In addition, will any spare parts needed come with the shifter ? (I didn't keep any spare parts that may have come with the brakes as my current shifter is clamped).
2 - I have this 10-speed ring on my SLX cranks. http://www.chainreactioncycles.com/octane-one-lock-narrow-wide-chainring/rp-prod127293 Will it work with a 11-speed XT chain ?
Thanks
Nick
Posted : 27/03/2017 12:32 pm
10 speed rings are fine, depends how worn it is though
I don't have a clue about i spec though, it's a complete mystery. What's wrong with clamps now? Bars are wider generally got the same or fewer things clamped to them. They should get in the sea.
Posted : 27/03/2017 12:53 pm
I agree with you but I really like the idea of a "clean" bar, purely for cosmetic reasons, and particularly with no rear shifter (I even removed the RS remote from the other side). Very shallow though !
Posted : 27/03/2017 12:59 pm
Not meaning to answer my own question not confuse the issue even more (is that even possible?) but I spotted this :
[URL= http://i1200.photobucket.com/albums/bb339/nickfrog1/ISPEC_zpsjgeuxbp8.jp g" target="_blank">http://i1200.photobucket.com/albums/bb339/nickfrog1/ISPEC_zpsjgeuxbp8.jp g"/> [/IMG][/URL]
I think by "2nd generation" it means I-spec B NOT I-spec II, which is massively counter-intuitive. Could anyone confirm please ?
Posted : 27/03/2017 1:52 pm
Anyone ?
Posted : 28/03/2017 5:04 pm
There was ispec A, ispec B and now Ispec II.
Old 10 speed stuff is either A or B. Ispec A shifters won't go on B brakes as far as I know but B shifters can be mounted to A brakes with the optional T nut.
11 speed generation (but also available as new 10 speed) - ie XT M8000, SLX M7000 Ispec II shifters can be mounted to Ispec A or B brakes with the Hope adapter (£11 each side).
The easiest way is to just buy the Ispec B versions of the shifters. If you think you may get the new M8000 or M7000 brakes in future then get ispec II with the hope adapter or bar clamp.
Posted : 28/03/2017 5:09 pm
Thanks but even confused. The shifter I want to buy and linked in OP is the 11-speed XT M8000. It comes in a B-spec version. But I don't know if my SLX M675 lever is B-spec ? The description says "2nd generation" ispec, but I don't know if that means B.
Posted : 29/03/2017 5:13 pm
I want to upgrade my tranny to 11-speed...
Posted : 29/03/2017 5:15 pm
Your slx brakes don't matter whether they are a or b, the IPec b shifters will be compatible with both. Just order from crc and make sure they are a retail boxed shifter when they turn up and include the i spec adapters as some of the oem stuff they sell may not include the correct adapters.
Posted : 29/03/2017 8:02 pm
Thanks a lot - and presumably if I ever upgrade my brakes to XT M8000 I won't be able to fit the B-spec XT M8000 shifter, or will I ? Cheers. Nick
Posted : 29/03/2017 8:25 pm
No, you'll need to buy a new shifter then. Unless there is a 3rd party adapter out by then or you can codge something yourself. I managed to get an I spec b shifter onto a pair of guides using some connecting bits and a lathe but it never was that good.
Posted : 31/03/2017 6:42 pm
Copied and pasted from the questions on the CRC link in the OP.
Compatible only with i-spec b shifters?
does 2nd gen i-spec mean i-spec b?
CRC Staff
Yes; These SLX brake levers are I-Spec B certified, this means I-Spec B compatible shifting levers mount directly to the brake lever clip.
Posted : 31/03/2017 10:57 pm
