Quick bodge questio...
[Closed] Quick bodge question: 9spd mech on a 1 x 10 set-up
Need to bodge for the weekend. There's a long story, but cutting it short:
Long-cage 9spd XT mech on a 1 x 10 system. Will it work? Or will I die?
Posted : 29/04/2016 7:54 pm
Nope
Posted : 29/04/2016 8:04 pm
pull ratios are different. you won't die but shifting will be rubbish
Posted : 29/04/2016 8:05 pm
Nope
Work or die?
Know that bit, but figured the pull ratio is actually controlled by the shifter.
That's what I was after!
Posted : 29/04/2016 8:37 pm
Cable pull at the shifter and leverage at the mech are both different to 10speed
Posted : 29/04/2016 8:53 pm
Gotcha - ta.
Posted : 29/04/2016 10:09 pm
Found this out the hard way recently.
Shifting actually felt ok, but the different pull ratio meant the mech didn't sit quite in the right place so ramps on the cassette would cause chain to slip under force. So shifted fine on workstand but an unpredictable nightmare to ride.
Posted : 29/04/2016 10:14 pm
My 10sp tourer has Tiagra shifters and a 9sp xt rear mech which is apparently the correct pull ratio. Is that correct for mixing road shifters with mtb mech?
Posted : 30/04/2016 5:58 am
