Quick 1x7/8/9/10 Sp...
[Closed] Quick 1x7/8/9/10 Speed question
Tempted to revert a 3x9 geared set up back to 1x9 primarily for a bit of a weight saving ๐Ÿ˜ณ
Is it worth upping the front chainring to make better use of the rear cassette?
Its [s]fairly[/s] really flat around here and I find I only probably use 5 gears max ๐Ÿ˜• when in the middle (32t) ring.
Upping it to 34t or 36t would I guess use the spread of gears better (11-32) block.
Am I talking gibberish or is there anything in this?
Posted : 09/05/2012 4:49 pm
Bump for the night folks
Posted : 09/05/2012 9:31 pm
I run a 34t with a 11-36 block and I'm running 10 speed. You may find you will need the 36t but have aplay and see how it goes, especially as you say it's flat.
Posted : 09/05/2012 9:36 pm
If you intend to use in a fairly flat area then yes I think I would
Ive got 34T, 11-32T (were cheap at the time) on my XC Hardtail which gets used in flatter local to not 'national park'* steep/high hills terrain, though rarely for more than 3hours
It takes a fairly steep, long, or loose/techy up for it to become unrideable, though some determination is required
If you've not really got a lot of steep/long climbing to do, then a 34,36 or bigger chainring would give better road gearing, and spread yhou typical 5 gears of wear higher up the block onto higher tooth number sprockets, hopefully making it last longer.
If its really gloopy/muddy out (depends on your local mud?) then you might want a spinnier gear?
Bigger chainring will weigh a little more though
Posted : 09/05/2012 9:59 pm
Well I run a 34:16T single speed if that helps in suffolk. 34-11 seems fine to me on flatish ground.
Posted : 09/05/2012 10:08 pm
