Question about nipp...
[Closed] Question about nipples (not the fun kind)
I'm replacing the rim on my rear wheel and the online calculator tells me I need 272 mm spokes. My current ones are 274 mm with 16 mm nipples, do you reckon I could get away with just using different length nipples? And if so, would it be 14 or 18 mm nipples I'd need?
Posted : 23/08/2015 4:50 pm
 Bolt
In theory but what length nipples did you put into the calculator?
Are the rim erd's the same?
Posted : 23/08/2015 5:07 pm
4 mm difference in ERD, the calculator is based on 14 mm nipples but spat out the right number for the current (broken) rim (274 mm).
Posted : 23/08/2015 5:13 pm
Not if the calculator's saying 272mm with 12mm nipples (as they normally use in their calculations)
Posted : 23/08/2015 5:15 pm
 Esme
The fun kind??? ๐Ÿ™„
Posted : 23/08/2015 5:19 pm
Guess that depends on your definition of fun!
Posted : 23/08/2015 6:59 pm
