QR for Chisel seat ...
[Closed] QR for Chisel seat post?
Hopefully someone's been through the same search for a solution... I'm riding a 2019 Specialized Chisel and occasionally get on to trails where it's worth dropping the seat. Stopping short of going for a dropper post just yet, I hoped to swap out the seat clamp for a quick release but cannot find one that fits. The width needed is 30.8mm which falls between common sizes available in the ususal places.
Does anyone know where to source a 30.8mm QR seat clamp, or have a cunning plan to make it work another way?
Posted : 03/02/2021 12:41 pm
That's the seat post size, not the seat tube size. The seat tube is bigger than the seat post. I think it will be a 34.9 mm clamp.
https://www.chainreactioncycles.com/brand-x-qr-seat-clamps/rp-prod118837
Posted : 03/02/2021 12:49 pm
No, the seat post size is 27.2mm. The clamp size needed is 30.8mm. I'm aware they're less common sizes
Posted : 03/02/2021 12:50 pm
Did you measure it with calipers? Spesh have been using 30.9 mm seatposts for many years.
Posted : 03/02/2021 12:53 pm
Yes I'm sure. Besides the fact it's written on it, I have tried a 31.8mm clamp that is too loose - you can see their own spec here https://www.specializedconceptstore.co.uk/product/13658/2019-men-s-chisel-expert/
Posted : 03/02/2021 1:51 pm
Have you tried a shim under the clamp?
Posted : 03/02/2021 2:31 pm
Salsa do / did the Flip-Lock in 30.6mm which you might get away with.. available here (but only in pink).
Posted : 03/02/2021 3:01 pm
Looks good thanks - website says to get in touch if you need a size not listed so I’ve done that. Fingers crossed.
Posted : 03/02/2021 11:17 pm
Is it possible to cannibalize a QR to convert your existing clamp?
Posted : 03/02/2021 11:52 pm
It's so narrow that I can't get existing QR bolt to work. Similarly using a shim kind of works but stops me using it as an easy to way to lower/raise seat quickly on trails.
Posted : 04/02/2021 9:44 am
How about a cheap dropper post with the lever under the saddle. We got a Decathlon one for £50
Posted : 04/02/2021 1:48 pm
In my Spesh camber manual it recommended the Salsa QR if you didn't want the spesh one.
Posted : 04/02/2021 3:37 pm
I'll look into that - dropper post definitely on shopping list but again, the narrower than usual seat post (27.2mm) limits choice. There's a good youtube tutorial on one that works well with the Chisel though.
Posted : 04/02/2021 5:03 pm
