Putting a 140mm tra...
[Closed] Putting a 140mm travel fork on my 2016 Tallboy?
I've been told it will slow down the handling due to the slacker head angle, would it be noticeable? If so in what way? I know this is a xc bike but how would the bigger travel forks alter it?
Thanks.
Posted : 29/01/2016 5:23 pm
It will slow it down a bit. If you get a fork with 51mm offset, that will help things a bit. I run a 120 sid and 140 pike on my 29er, no probs.
May feel like it wanders more on climbs but should be more stable on the downs.
Posted : 30/01/2016 7:23 am
a ran both 140mm 34's and 140mm Pikes on mine at one point or another, very capable, front end was quite high for me (5'6") hence the Syntax stem when i switched to Pikes,
[URL= http://i1272.photobucket.com/albums/y394/dansipods2/CCA59EEF-9013-45A6-AA8A-9F79CEBBB1D1-5241-00000201EBBF04BB.jp g" target="_blank">http://i1272.photobucket.com/albums/y394/dansipods2/CCA59EEF-9013-45A6-AA8A-9F79CEBBB1D1-5241-00000201EBBF04BB.jp g"/> [/IMG][/URL]
[URL= http://i1272.photobucket.com/albums/y394/dansipods2/487444_10153971824840506_942466681_n_zps8ed9ce86.jp g" target="_blank">http://i1272.photobucket.com/albums/y394/dansipods2/487444_10153971824840506_942466681_n_zps8ed9ce86.jp g"/> [/IMG][/URL]
Posted : 30/01/2016 8:27 am
I've been looking at rockshox
rct3 140 mm, but I see they do a 130mm, this might be a compromise, would I still need 51mm offset with the 130mm? I'm
6 ft 1 if that helps any.
Posted : 30/01/2016 10:08 am
I'm running 150mm pikes on mine and don't really notice anything detrimental.. ๐Ÿ˜€
Posted : 30/01/2016 11:11 am
Like that dirty, very nice....
Posted : 30/01/2016 1:10 pm
