pushed shock questi...
[Closed] pushed shock question
The frame I bought has a pushed fox dhx coil. The previous rider is a bigger lad than me. As a result I have a lighter spring. Do i need it repushing?
Posted : 19/11/2011 5:48 pm
 LoCo
The damping 'tune' should be matched to the spring rate used by the previous owner, the damping is adjustable with a full strip.
Posted : 19/11/2011 5:50 pm
Can you give me details in bog basic English please. Also what will the cost be, whats the turn around time? Cheers si 🙂
Posted : 19/11/2011 5:56 pm
Costs can be found on here:
http://www.tftunedshox.com/service/fox.aspx
I would recommend having it re-done ideally but give them a ring and see what their opinion is 🙂
Posted : 19/11/2011 5:57 pm
Cheers, was aimed at Loco tho
Posted : 19/11/2011 6:00 pm
 LoCo
Depends on what's needed if it's been recently serviced it can just be stripped retuned (shims removed/changed to suit rider weight and bike suspension system) ~£30
If a full service is needed there would be a additional charge ontop of the service cost.£65 + £15
Posted : 19/11/2011 6:47 pm
Loco, on this note i've another question.
I have an RP23 shock that is set to the 'medium' tune but i'm only 9 stone or so in weight so would it be worthwhile having it retuned to the 'light' version?
Thanks.
Posted : 19/11/2011 6:50 pm
loco - if i speak to tftuned on monday and they say it needs refettling, how quickly could you do it? email me if you wnat to keep this off thread. cheers buddy
cruz.heckler@gmail.com
Posted : 19/11/2011 6:53 pm
 GW
muddydwarf - tunes depend on the bike too.
Posted : 19/11/2011 7:12 pm
GW - good point! Bike in question is a Marin Wolf Ridge QuadLink II so how that affects the tune i've no idea...
Posted : 19/11/2011 7:13 pm
 GW
me neither. 😆
Posted : 19/11/2011 7:14 pm
Loco - have emailed you info@locotuning.co.uk
Posted : 19/11/2011 8:15 pm
 LoCo
Ok will respond to any queries tomorrow (maybe) or Monday, need to spend some time with my daughter and wife 😀
Just popped a quick responce on the thread as it happened to pop up when is was scanning stw while doing other stuff, have a good weekend!
Posted : 19/11/2011 8:16 pm
you too 🙂
Posted : 19/11/2011 8:23 pm
Having the shock on your marin push tuned or shim stacked by someone will make a huge difference. J tech did the on mine and the bike was so much better after, didn't blow through it's travel too easily as the original shock set up did.
Posted : 19/11/2011 8:38 pm
When a shock is pushed - does it make the boost valve/chamber redundant or do i need to change for my weight? Would a >value in this make the ride harsh?
IS "bottom out" resistance a personal thing like rebound?
Posted : 20/11/2011 11:58 am
Speak to TF Rob, be patient. 😉
Posted : 20/11/2011 12:07 pm
mat -me n patience are not a usual combo!! I will ring em tomorrow but in all honesty don't want to have to ride on the road until it comes back (if it goes away) 🙁
Posted : 20/11/2011 12:35 pm
 LoCo
You'll have it back for the end of the week Cruz 😀
Posted : 21/11/2011 10:53 am
