Pushed RP23 stupid ...
[Closed] Pushed RP23 stupid question...
[#3237263]
..(that I should probably ask TF).
Anyway just had my rp23 pushed. I know that its no longer possible to make the shock fully open, however am unsure if the controls do anyhting now or not (other than the rebound which I know still does that). So does the 3 position dial do anything (thinking this might still adjust platform level) and does the 2 position lever do anything?
Posted : 12/10/2011 11:44 am
From what I understand of the pushed tf option all you levers still do exactly what they used to but the way the shock is set up is far more optimal for you as a rider.
All shocks pretty much are set up from the factory for the 'average' rider who weighs an average weight etc etc and rides an average way. By pushing the shock you've had TF gut it and set it up with you and your weight/riding style in mind. They've changed seals and internal pressures only available at factory level.
It should now ride really sweet...enjoy!
Posted : 12/10/2011 12:19 pm
ah ok, thanks, that sounds good. Looking forward to the first ride to see how it feels.
Posted : 12/10/2011 12:42 pm
I have a Pushed RP23 and I can't tell any difference between having the ProPedal level on or off (or in any of the three positions). Whether that's because I'm totally incapable of detecting the difference or they don't make any difference I'm not totally sure so I'd be interested in the answer...
Posted : 12/10/2011 12:47 pm
I had the same problem on a quick bench test after refitting, hence the question.
Posted : 12/10/2011 2:48 pm
