Hope Pro 2 rear hub...
[Closed] Hope Pro 2 rear hub with 12mm axle
[#3237290]
Read on here somewhere the 12mm axle on Pro 2 rear hubs are susceptible to breaking, and that the new Pro3 is stronger
I am running this at the moment
Is it a disaster waiting to happen, or rare occurence?
thx
Posted : 12/10/2011 11:47 am
Any hub will break if you try hard enough.
Just stick with what you have...
Posted : 12/10/2011 11:50 am
Some riders break them every few rides, some get years of use. You might be fine, or upgrade the hub to Evo with a stronger axle... that's what I did.
Posted : 12/10/2011 12:05 pm
You can upgrade the internals to Pro 3 if/when it breaks.
I've been using 12mm axles on Hope Pro II hubs since 2006 and never had one snap. Just be careful with a Maxle light axle as the middle section is machined away so doesn't support the axle in the same way as a normal style Maxle (or other 12mm axles).
Posted : 12/10/2011 12:10 pm
rickos - I'm using a 12mm Shimano thru axle so sounds like that's okay?
cheers fella
Posted : 12/10/2011 1:41 pm
Yep, problems when using a Maxle lite, but fine with solid through-axle.
I happen to have a fitted, but unused, 12X135mm Pro2 kit for sale, and a Superstar 12mm axle. email in profile...
Posted : 12/10/2011 1:55 pm
