At On One £233 for 160mm 27.5 non boost
https://www.planetx.co.uk/i/q/FORSYARC/rockshox-yari-rc-solo-air-160mm-fork
Hell's tits. That's a good price.
Oooft that's tempting.
Am I correct in thinking these can be reduced down to, say, 130mm?
With a different air spring
Cheers. Swap over the charger damper and I've basically got a new set of Lryiks for £233
That's a very good price, I have seen them for more than that 2nd hand recently
One more question: when changing the air shaft, you can fit the one from the 19 Model with the larger negative air chamber as well, can't you?
One more question: when changing the air shaft, you can fit the one from the 19 Model with the larger negative air chamber as well, can’t you?
yes you can.
Balls. Thanks for the PSA OP, there goes my bank account 😀
Cheers. Swap over the charger damper and I’ve basically got a new set of Lryiks for £233
Plus the cost of a charger damper, so a bit more than £233!
Yay!! New forks!! Thanks OP
Was just thinking tonight that it was about time my Covert had some proper tapered forks rather than the straight steerer revs with an adapter..
*are straight steerer forks still saleable (Revs with black box insidey bits)
breadcrumb - not at all. I already have the charger unit
Then buy an Avalanche damper and have a fork that would make a £1000 36 feel stiff and awkward for 1/2 the price.
breadcrumb – not at all. I already have the charger unit
Ah, that makes sense then. I recently bought a new to me bike with Yari's. I was set to pull the damper from my Pikes but they aren't compatible..
An i being paranoid, or had anyone else who ordered these had an order confirmation? The money is earmarked in my account, but nothing showing in my order history, and no confirmation email ..
Had an order and dispatch email. Will they turn up?? Well that’s another question
Carlos
Or, spend a little more on the mattocs that have been posted as a PSA on the forum? A vastly superior damper.
John
Order page now gone. So either someone has made a boo-boo or they're all gone.
I place my order about 8 last night and have had nothing :/
mattoc pro at crc..
£299
Well, Planet X have predictably cocked up and taken my money despite not having stock, it seems. Yay.
Don't forget the BC discount works on the Mattoc, so £269 if you have BC...
I've had an OOS email too.. haven't checked to see if they have taken the money
No OOS email for me, last I has was a dispatch note. No tracking or anything so will give it till the end of the week then chase up
Forks have just turned up.
Not in a RS box, no shock pump, booklet or service kit but I'm not complaining
Want to sell them to me for £235?! 😀
If only these were in 29er form...
...anyone know of any outlets doing a good deal on a 29er Yari?
There's a dual position air 29er on Amazon for 300 quid
Thank you! I'll check it out.
Submarined - <span style="font-size: 0.8rem;">Want to sell them to me for £235?!</span>
They're going on the bike (eventually) once the current Lyriks get beyond usable
Carlos
