PSA XT Shadow Plus ...
[Closed] PSA XT Shadow Plus rear mech £35
[#6548619]
On One.
[s]24[/s] 23 left.
Posted : 12/10/2014 12:21 pm
 cdoc
125mm drop Reverb for £139 too!
Posted : 12/10/2014 12:45 pm
Just what i am after. ..is this medium cage or long cage i cant tell and why is it cheaper than other one looks the same
Posted : 12/10/2014 12:54 pm
There was a post on here about them being long cage...think they advertised as GS but delivered SGS as their systems had the wrong inventory.
[url= http://singletrackworld.com/forum/topic/shimano-rear-mech-cage-length-confusion ]Post[/url]
Posted : 12/10/2014 1:07 pm
tmb467 - That thread suggests that they are indeed GS
Posted : 12/10/2014 1:36 pm
It suggests that they are indeed [b]listing as[/b] GS, but at least 1 customer has been sent a SGS
Posted : 12/10/2014 1:44 pm
So with a 2x 10 (11-34) which would fit best ?
Posted : 12/10/2014 1:53 pm
Bugger. I hope they've got it right and they're GS...
Posted : 12/10/2014 2:07 pm
@iainc:
SGS capacity up to 43t
GS capacity up to 35t
34 - 11 = 23.
Add that to the difference between your two front rings and it will almost certainly amount to less that 35t.
SGS usually used for triple's.
edit:
Just seen your other thread where you say 11-36 & 24-38
That's 25 + 14 = 39 so outside the range of the GS. Might work presuming you never shift into the larger cogs front & back at the same time.
Posted : 12/10/2014 2:13 pm
@kwack - only difference I can see is 'oem' in the product code.
Posted : 12/10/2014 2:14 pm
Umm how does this apply to 1x10? If I'm 30t front and 40t rear will the GS work?
Posted : 12/10/2014 2:17 pm
If it's 1x10 then ignore the front.
Capacity just= difference between rear sprockets.
Though whether any specific rear mech will work well with a (presumably) extended casette ...
Posted : 12/10/2014 2:20 pm
Johnny - many thanks, I've learned something today !
front is 24/38, so that's 14 plus the 23 at back, so at 37 I guess I'm on a long.
At least now I know how to work it out !
Posted : 12/10/2014 2:23 pm
See my edit above.
Posted : 12/10/2014 2:26 pm
thanks Johnny, appreciated
Posted : 12/10/2014 2:30 pm
Medium and long cage all work ok with 1x10
Long cage just takes a little bit longer to shift and looks a bit naff... 🙂
Posted : 12/10/2014 4:07 pm
I'd be interested to see if I was the only one that received a SGS (i.e genuine, one-off packing mistake) or if they are basically labelling up to just about get away with legally shifting some stock they know they wouldn't, if labelled clearly and correctly.
Posted : 12/10/2014 4:18 pm
It was definitely a SGS they shipped to me. I ended up buying a Zee instead and it's converted me to using a short cage mech for 1 x 10. Much neater.
Posted : 12/10/2014 4:21 pm
GS works fine with 24/38 and 11/36
SGS works with anything
Posted : 12/10/2014 4:22 pm
Just ordered one at that price its worth the risk. If its the wrong one will take it back. If its a sgs an the cage be taken off and a gs one fitted.
Posted : 12/10/2014 4:37 pm
 cp
Not sure how on one keep getting away with advertising cheap prices and yet every option listed is far more expensive.
Posted : 12/10/2014 5:13 pm
be interested to know which one turns up
Posted : 13/10/2014 11:27 am
Mine says its posted so will keep you up to date
Posted : 13/10/2014 1:14 pm
I have just picked up one of the XT mechs from the post office, its a long (SGS) cage one.
Posted : 13/10/2014 1:55 pm
That sucks. If mine comes as an SGS it's going straight back.
Posted : 13/10/2014 10:14 pm
If anyone gets a long cage one and is going to return it I'll happily buy it at £35 🙂
Posted : 13/10/2014 10:27 pm
 nuke
£39.99 on Ribble (free P&P) for SGS and GS. Plus when I bought from them, they sent me the cage length I ordered...Bonus 😉
Posted : 13/10/2014 10:31 pm
nuke - Member
Yep. And when I ordered one a week or so ago they had a fiver off promo.
Posted : 13/10/2014 11:27 pm
Mines arrived, its a long cage, spoke to them and they aren't aware of the problem so will be sending it back.
Posted : 14/10/2014 10:44 am
 hora
How long do they work for before you have to [s]bin[/s] sell them secondhand?
Posted : 14/10/2014 10:50 am
 cp
How long do they work for before you have to bin sell them secondhand?
Doesn't matter, you can't buy them for £139 anyway. £199 is the cheapest available on on-one, despite what they claim.
Posted : 14/10/2014 11:15 am
I have ordered one of these and hoping that it IS a long cage. If I get a short one I can swop 🙂
Posted : 14/10/2014 11:22 am
 hora
So they are being dodgy.
Posted : 14/10/2014 11:23 am
Back to the Mechs!
Mine's come.
For comparison,
My 9sp XTR Shadow SGS jockey wheel centre's distance = a smidge under 100mm
My 9sp XT Shadow GS jockey wheel centre's distance = a smidge under 80mm
This thing's jockey wheel centre's distance = a smidge over 95mm
So, SGS then. It's going back.
Posted : 14/10/2014 8:26 pm
that's exactly same as my current SGS one indeed !
Posted : 14/10/2014 8:39 pm
I assume these mechs are coming unboxed?
Posted : 14/10/2014 8:41 pm
do you need a box?
Posted : 14/10/2014 8:47 pm
Unboxed in bubble wrap. Offered to drop mine in to one of the stores to swap it but they cant do that as the stores done have gs ones so its gone back in the post. Did anyone get a gs one or were they all sgs been sold on as gs. Guy I spoke to seemed to think it was just mine.
Posted : 14/10/2014 8:51 pm
Iainc, still think a GS would work with your setup. How often are you likely to shift into small/small? The mech will complain before you get there (EOEE & YMMV of course).
Posted : 14/10/2014 8:54 pm
Tracey - Guy you spoke to would appear to be very wrong.
Posted : 14/10/2014 8:55 pm
Johnny, i agree however I am after a spare one and currently have a long which works fine. I never go big big but do sometimes go big and second biggest at back
Posted : 14/10/2014 8:58 pm
My original post was re-posted in this thread and I added a comment to this thread. Why are people peeved they got SGS's after reading the advice earlier (shakes head)? Of course the guy at On One seemed to think each one was a one off error.
Posted : 14/10/2014 9:00 pm
No you don't need a box but that would have a code on it that told you what the mech is. When this topic came up a while ago I measured the cage on a GS 10 speed mech and reported that it is 95mm between jockey wheel bolts.
Posted : 14/10/2014 9:14 pm
Measured four of our gs ones, all XT 10 speed clutch mechs, including one in a box waiting to be fitted to replace a damaged one and they all measure 80mm the one delived today measured 100mm. Something isnt right as there cant be that much difference in cage lengths if they are indeed gs.
Posted : 14/10/2014 9:43 pm
Indeed.
Posted : 14/10/2014 9:48 pm
