PSA: XT M785 Brakes
[Closed] PSA: XT M785 Brakes
Couldn't resist a quick peek. They come with normal pads - not finned (OE brakes I guess).
Levers are so tiny, I can see why somebody above runs them outside their shifters!
Nice free mug included too.
Posted : 24/08/2011 10:05 am
Excellent, mine should be here today too.
Got emailed a 10quid credit note from them for the Facebook voucher.
Plus a free mug to go with my bowl?
Can't be bad 🙂
Posted : 24/08/2011 10:34 am
BTW, for those that asked, I'll be doing the hose swap (have done it a few times before), so will do photie instructions for posting up here.
Posted : 24/08/2011 10:36 am
I'm in too. To be honest, even at full RRP these seemed great value. £125 a pair is mental.
DezB - I'll probably be making use of those instructions, cheers.
Posted : 24/08/2011 10:43 am
 S_J
I've jumped on the bandwagon as well! Couldn't resist at those prices.
I'm assuming the adaptors haven't changed to mount the calipers? Hoping to re-use the Shimano ones I've got already
Posted : 24/08/2011 11:09 am
Mine arrived also. They come with one spare olive and connector (you only need to buy one if you're planning on doing new ones). Can confirm non-finned pads. Levers are tiny tiny tiny.
And a free mug, and two packs of free sweeties. And my XTR BB.
Posted : 24/08/2011 1:00 pm
I've read a good plan for the hose swap without bleed is to take the bleed block out, engage the lever a little to push the pistons out, then when reattatching the hose, use a spacer to push the pistons back in, pushing fluid through the system until you have a meniscus at the end of the hose.
Make sense?
Posted : 24/08/2011 1:02 pm
DezB - good lad!
So for those of us that want to shorten the hoses, even if I'm careful with the cut I guess there would be some leakage. Can I just put a bit more fluid into the hose before reconnecting?
Posted : 24/08/2011 1:11 pm
continuity, i have used that trick of "burping" when Ive shortened hoses-this is on used brakes so already have some piston movement to push back with. Worked fine every time.
thebunk, see above, if youre careful you wont even need to top up fluid. This has been mentioned in a few brake bleed threads, if you forum search "M775 brakes" youll probably find a few blow by blow how too guides as these brakes seem to cause a few headaches.
Posted : 24/08/2011 1:23 pm
Mine arrived today.
I went for the silver ones.
They came with a mug and a couple of bags of sweets.
Amazing price and service, I'll use them again!
Now to fit them...
Posted : 24/08/2011 1:34 pm
Cool. Just sold my old juicys, and bought some of these. And some Conti GP 4000s for just 27 euro each - my local shop wanted 50.
Posted : 24/08/2011 1:38 pm
anyone measured the weight of these?
Posted : 24/08/2011 1:40 pm
Any cheaper replacement pads for these available yet ?
Posted : 24/08/2011 2:22 pm
Superstar do new XTR ones - are the pads the same for the XT does anyone know?
Posted : 24/08/2011 2:28 pm
Do they do the finned XTR pads?
Posted : 24/08/2011 2:35 pm
Think all new style calipers use the same shape pad (pin in middle), which is different to all the old ones (pin on side).
Posted : 24/08/2011 2:37 pm
New XTR and new XT are the same shape, they look like this -
Or like this with fins -
As far as I know only genuine Shimano come finned at the moment but would be happy to be proved wrong on that.
Posted : 24/08/2011 2:41 pm
Cheers Mister P and others.
I'm sure someone said the SSC ones are un-finned. I'd prefer them that way to be honest - less bits to fall off or go rusty prematurely.
Posted : 24/08/2011 2:43 pm
My Xtr s just came. They are the trails with the finned pads for 280 bargain.Forgot to say I bought the new xt s a month ago and their awesome brakes you all will be mega happy with them. The ice tech rotors do make a difference though
Posted : 24/08/2011 2:45 pm
Those fins are borrox.
Posted : 24/08/2011 2:46 pm
Oh no only one spare insert damn.
My tiny bike will need both shortening I'm sure.
Best try and find these new insert spares.
Just ordered mine :). How long are they taking to turn up?
So just to make sure for the deore this is the olive and insert I need?
http://www.chainreactioncycles.com/Models.aspx?ModelID=69605
Posted : 24/08/2011 3:03 pm
Yep that is the fella. The olives are all the same but the insert is silver where as the older ones are gold coloured so you can easily tell them apart.
Posted : 24/08/2011 3:10 pm
About 3-4 days daveagiles. I ordered saturday, got here today.
Posted : 24/08/2011 3:11 pm
My mistake. Rosebikes threw in an extra set of olive+conn anyway.
Posted : 24/08/2011 3:18 pm
Ok, I switched over and bled. Found a PDF online talking about changing hose without bleeding:
Followed and works, no air in system, shortened, switched.
Just don't forget to switch at the lever, not the caliper! 😉
Posted : 24/08/2011 5:31 pm
No fins? Sorry nmdbase. But at that price they're a steal.
I'm currently running the (unfinned) Superstar New XTR pads (S5). Feel great.
Saving my fins for high braking (dragging) trips away.
That "burping" technique in the PDF does work a treat.
When I shorten/swap levers I also fill the brake lever hose aperture with fluid before I refit the hose to minimise getting trapped air inside.
Posted : 24/08/2011 7:39 pm
Die Sendung hat das Import-Paketzentrum im Zielland verlassen.
Woooooooooo shouldn't be long now!
Posted : 24/08/2011 8:01 pm
Roll on payday, hopefully the price stays the same!
Posted : 24/08/2011 8:20 pm
All set up.
As to weight, they come up to me at about 15g heavier than my elixir r carbon's (like for like), but that was with pre-cutting hoses so it's probably a wash or very slightly in avids favor.
Posted : 24/08/2011 8:28 pm
Continuity where's the pics mate. How do the new levers feel?
Posted : 24/08/2011 8:34 pm
aint got mine yet,
the ice tech rotors make a difference then? was thinking my hope floating rotors may be ok ?
Posted : 24/08/2011 8:52 pm
 fbk
Continuity - I'd be interested to hear how you find these compared to your Elixirs?
Posted : 24/08/2011 8:58 pm
I haven't had a chance to ride them yet. I'm using my old avid adapters and Avid Cleansweep G3 185mm rotors. Icetech rotors won't increase your braking power in this country, just reduce temps for big mountain descents (30min plus e.t.c)
Incredibly positive feel to them - it's very clear where the bite point is and there is no compression beyond it (except in the front where I lost a little fluid whilst switching hoses - need to do a quick bleed).
The short levers feel good, though I still had to run the levers inside as I one finger brake only. They don't match my paint-work quite as well as the elixirs though! Much less flex both in the clamp and the lever - on the avid brakes a hard grab at the levers would move the resevoir side a good 2mm, these don't. A very solid feel in comparison - I certainly have a lot more confidence in them.
The only thing i'd worry is if they will be a bit grabby - but you can't tell that until you ride them.
I'll run these on my g3's, and if/when next summer i take the remedy on a bike trip I'll get ice-tech rotors and finned pads and new adapters. Oh, and some 10speed xt pods - the new shifter pods automatically match-make with these levers.
Best part? I sold my elixir r's secondhand on PB for £5 less than these cost new. Off to Cwm Rhaedr again tomorrow!
Posted : 24/08/2011 9:28 pm
Mine not arrived yet.
Those finned pads - £30 a pair!
Don't think I'll be replacing with them
http://www.chainreactioncycles.com/Models.aspx?ModelID=61810
Posted : 24/08/2011 9:38 pm
 fbk
Thanks for the info - I await the results of the first ride 🙂
And I've got the same problem with matching colours - it would take a lot to get me off my Elixirs but I am tempted!!
Posted : 24/08/2011 10:00 pm
I am really tempted by these as I'm not too happy with the elixir 5s that came on the fuel. I'm even more tempted by the xtr's purely from a looks point of view! Which is a shame because Rose dont seem to list the £288/pair deal any more 🙁
Posted : 24/08/2011 10:26 pm
without readin the whole thread, how much are these brakes, and what do you get?
I may be getting a fair few sets of these and want to make sure I can sell them 🙂
Posted : 24/08/2011 10:30 pm
I'm sure someone will dedicate themselves to finding your posts and linking rosebikes in the thread 🙂
Posted : 24/08/2011 10:34 pm
lol, OK i'll shut my trap.
Posted : 24/08/2011 10:37 pm
 S_J
Limited availability on the black ones now. Get in quick if you're after some of these!
Posted : 25/08/2011 9:38 am
I wonder how many sets they had to sell, I imagine MTB forums all over EU are also pointing other workshy folk at these brakes and theyve been on offer for a while now.
Posted : 25/08/2011 9:47 am
I ordered 2 sets of silvers, but just called to change one set to black. Fantastic service and unlike CRC, the person at the end of the phone was very helpful and sorted it out right away.
Posted : 25/08/2011 10:12 am
[i]unlike CRC, the person at the end of the phone was very helpful and sorted it out right away[/i]
NEVER had a problem with CRC when phoned. Always been very helpful. (For balance, like)
Posted : 25/08/2011 10:17 am
Fair enough - only ever had to call them once and it was a painful experience!
Posted : 25/08/2011 10:46 am
 S_J
I think the STW massive must have pretty much cleared them out of stock!
Posted : 25/08/2011 10:51 am
They're not pretty, are they? That big chrome reservoir is an ugly lump of a thing.
Posted : 25/08/2011 11:01 am
was just gonna say, they dony look to pretty on the bike...thought they would look better than that! the old ones looked outdated, but the new ones look pretty awful full stop 🙁
formula all the way!
Posted : 25/08/2011 11:05 am
Function over form, I suppose. I quite liked the look of the old ones. As long as they do the job, I'm happy enough,
Posted : 25/08/2011 11:09 am
the xtr ones look nice, though whether or not they do on a bikes another thing, as i thought the new xt ones looked pretty decent on the site
Posted : 25/08/2011 11:10 am
They are ugly beasts arn't they.
I was tempted, but I don't really [i]need[/i] to change.
The XTR's look acceptable, but the cost difference isn't!
Posted : 25/08/2011 11:12 am
They're not pretty like formulas, but it always takes a while to get used to new Shimano designs.
[i]They're not pretty, are they? That big chrome reservoir is an ugly lump of a thing[/i]
FS: Unused XT disc brakes. F & R.
Posted : 25/08/2011 11:44 am
:). I haven't even got them yet.
Posted : 25/08/2011 11:57 am
Shieeet. I think brakes are one thing where I'd choose performance over looks.
Lemme put it this way: I'd choose the looks of my face over the looks of my bike. Only just, but still.
Posted : 25/08/2011 12:06 pm
Had to order silver ones this morning as they were out of the black ones by the time i made it to checkout.
Not worried about what they look like - its defo an item of function over form.
Posted : 25/08/2011 1:24 pm
Mine just turned up and I think they look brilliant.
Love the new lever.
Came with 2 new olives and inserts a rear 160 adapter and a free mug.
3 days from ordering to delivery. That in my book is perfect Internet service.
Posted : 25/08/2011 2:58 pm
I'm hugely excited about this free mug, to be honest. I think it might be the best bit. Any pics?
Posted : 25/08/2011 3:17 pm
I've ordered two pairs. Does that mean I get two mugs?
Also, how do I stop myself from refreshing the DHL tracking page over and over again?
Posted : 25/08/2011 3:33 pm
Posted : 25/08/2011 3:34 pm
Cool. I think me and rose bikes are going to have a long and happy relationship.
Posted : 25/08/2011 3:40 pm
Me too mate me too
Posted : 25/08/2011 3:43 pm
For lazy people here are the links from earlier in the thread.
http://www.rosebikes.co.uk/article/shimano-deore-xt-disc-brake-br-m785--servo-wave--/aid:515724
http://www.rosebikes.co.uk/article/shimano-deore-xt-disc-brake-br-m785---servo-wave--/aid:515731
I think they are 66GBP and 63GBP plus a fiver delivery to the UK.
You don't get discs or caliper mounts.
Posted : 25/08/2011 3:45 pm
I see £63 and £66 Matt - not Euro,
Posted : 25/08/2011 3:46 pm
Too fast was editing!
Never do any one a favour 😉
Posted : 25/08/2011 3:47 pm
I think the rear does come with a 160mm IS mount too.
Posted : 25/08/2011 3:49 pm
Shot down in flames for helping lazy people.
There's no justice!
Refers to earlier post "Never do any one a favour"
Posted : 25/08/2011 3:51 pm
Posted : 25/08/2011 3:56 pm
Posted : 25/08/2011 3:59 pm
So that's what Americans are on about when they say they're looking forward to the Rose bowl.
Posted : 25/08/2011 4:04 pm
Rear comes with a 160mm mount I have it in my hand now
Posted : 25/08/2011 4:06 pm
Mine didn't?
Posted : 25/08/2011 6:18 pm
Nor did mine, or a mug. I bought a set of Xt brakes, an XTR bb and some new deore platform pedals and all I got was a reflective snap band (and excellent value for money)
Posted : 25/08/2011 6:19 pm
Nope no free mug for me either!!I wont be using them again now 😀
well i think they look good miself.
Posted : 25/08/2011 6:51 pm
I got a mug. Ordered monday and they arrived today
Posted : 25/08/2011 7:08 pm
I can cope with not getting a mug. It's the not knowing that's killing me.
Bet I won't. Never had Haribo from Wiggle either.
Posted : 25/08/2011 7:18 pm
if you dont get a mug then dont use em again 😉
Posted : 25/08/2011 7:31 pm
What if I get a mug the second time?
Posted : 25/08/2011 7:51 pm
Page 2 / 6
