PSA: Merlin Ultegra...
[Closed] PSA: Merlin Ultegra SL Triple chainset complete with BB cups £67.45!
with the VIP10 discount.
I don't need them now for my road bike for 6 months, but at that price! I can't see why they wouldn't work on an MTB (chainrings are not as low geared for sure) (but don't quote me on that). Perhaps the BBs aren't as well seal (but don't quote me on that either)
Posted : 22/12/2011 4:31 am
probably won't work on an MTB - "bb" is shorter and cranks won't clear the chainstays
Posted : 22/12/2011 11:55 am
They do usually fit actually. The main issue is that the chainline is different so unless you're going to single ring it, it won't shift properly or not without some bodging.
Posted : 22/12/2011 11:57 am
Nice one cheers, was waiting for a cheap triple to come along.
Posted : 22/12/2011 12:32 pm
Won't fit a 73mm shell - the axle will be too short, no room for an E-type front mech either.
May fit a 68mm shell (depending on crank clearance), but the rings are bigger as said, could be run as a double, but you'd still probably want to change one of the rings. If you're using the inner/middle positions you may encounter chain line problems and find it won't shift down.
Unless you need a road triple I'd not bother, more potential faff than it's worth, not that much cheaper than SLX really!
Posted : 22/12/2011 12:37 pm
Are these 9 or 10 speed or doesn't it matter.?
Posted : 22/12/2011 12:42 pm
Doesn't matter, but Ultegra SL was a 10 speed group.
Posted : 22/12/2011 12:43 pm
I was looking at a new lighter triple for the road bike but my current setup is nine speed. Would my current shifter still work.?
Posted : 22/12/2011 12:46 pm
 cp
neilsonwheels - yes, so long as your shifter is triple it'll work. The chainline (measured middle of bb shell to centre of middle chainring) may be different to your current cranks, so you may need to tinker with end stops and cable clamp on the front mech, but the cranks will work fine.
Bargain price that if anyone is after a triple...
[EDIT] they will work as long as your frame is english threads!
Posted : 22/12/2011 1:26 pm
Its a triple!! ok, i suppose if you got weak lady legs
Posted : 22/12/2011 1:28 pm
Oh Steveaustin you say the sweetest things.....
Bought one!
Thanks
Posted : 22/12/2011 1:33 pm
Shoulnd't need to.
The cranks will work regardless - the BB won't fit a frame with Italian thread though!
Posted : 22/12/2011 1:39 pm
Posted : 22/12/2011 4:32 pm
