No. The benefit is being able to view what you are recording through an app on your phone, albeit with a bit of lag. I don't think there is anything more to it.
Hmmm, I'm not sure how much use that would get tbh. Is the non wifi the same in all other ways then?
You can change settings and see what is in frame using a phone - so if it is helmet mounted or somewhere else that isn't easy to check (chest mount), then the app is handy.
Non-wifi is the same but appears to have 2 versions of the original. The latest firmware for the Non-wifi also appears to change true 1080p to 'double' 720p.
Just to save me trawling through all the previous posts what is the benefit of wifi for this, is it simply to upload without cables?
Thanks
I have a Contour HD and I have recorded days of filming the ground or front wheel. Being able to look at what the camera can see when it's on my helmet is why I think the wifi to phone will be handy.
mine turned up on xmas eve and after using it on a trip to Winter Wonderlan in Hyde Park and the xmas lights in and around Oxford street last week have to say I'm impressed.
Original charger went straight in the bin (as with all Chinese power supplys where possible) and charges and transfers data nice and quick. Just need to source a 2nd battery now and a pole to stick it on for ease of filming and I'm all set
The wifi is good but the app is very basic. Allows changing of settings and viewing the camera image so works but it isn't a polished looking app. Still handy to have thought to check shots and stuff.
DickBarton.......I have charged it from computer and it still doesn't turn on ...it's being sent back for a refund hopefully ...I've now bought my boy a £99 GoPro instead
Ah sorry I thought the plug charger popped and you hadn't tried another source...sending back sounds sensible.
I know its a bit more expensive has anyone gone for the SJ5000?
@Orange Lad: [url= http://www.techmoan.com/blog/2014/9/22/at-last-its-the-real-sj4000-wifi-review.html ]probably not.[/url]
@spacemonkey I meant like this one http://www.sjcam.com/en/home/32-sjcam-sj5000-wifi-action-camera.html
which retains the same case unlike the one in the video on tech moan
My first "film" too mch cam shake and sometimes a poor angle on the rucksack strap, need to do some adjusting.
Picked up a sj4000 from accmart. Firmware was 20141122v02. After a fair bit of reading it looks as though that firmware isn't currently updatable and the camera needs specifically the original firmware to work. I tried updating with various FW versions but to no avail (also got the double sparkle sound of on and off with black screen). Once i reinstalled the original firmware it came back to life. I have a copy if anyone needs it.
Was hoping to use the timelapse function but this versions doesn't seem to have it and doesn't look like it will be upgradable unfortunately 🙁 unless of course i am mistaken.....
inigomontoya
You need that on ure head mate,it'll stop the wobble,unless you're heads loose !!!...lol
I have the same firmware version mau00149, Shame about the time lapse, wanted to do some footage of my boy building Lego 🙁
Reedspeed, don't like the weight on my helmet, i was happier with this, using the handlebar mount, colours came out much better without HDR. Not sure where the black border around the video has come from though Snowy mtb ride on the Malvern Hills 2015:
Inigomintoya
What editing software are you using ?,I've downloaded the gopro one & don't really like it !.
Windows live movie maker, I had to install a codec to get it to work with the .mov files, and is quite slow initially loading but then is OK for the editing bit, still learning though! Have you got any videos you've done using the gopro software?
I'll try that then ,what's a codec ??. Lol .
No mate,not really,to be honest like yourself,I'm playing around with it,I've had an issue with the sd card,& had to re format it,apparentley it's a common fault with this camera,as great a value as it is,it does have some floors,I keep buying stuff,spare batteries etc, but I'm getting there .
Have you been on techmoan ?,that's informative,& there's a forum too like on here, v helpful !.
Finally had a chance to get out with mine last night and can say that the quality of the night (with lights) footage is very good. Very good value for money..thanks to the OP for the original post 😀
As a penny pincher, trying out the accmart £38 option on Amazon. Doesn't even say SJ4000 in the product title, but hey - even if it is a fake, how much worse are the fakes than the "real" SJ4000? Will see when it arrives anyway!
Here's my nightime footage. Please excuse the credits etc as I've never used WMM so just having a play..Only appears to be in 360p 👿
Should have gone right at the bottom of Mr conker, then left into rose bank, best little steps for jumping down 🙂
Did the steps.. 🙂
That works better at night than I though it would. Might take mine out next time too 🙂
Has anyone got any recommendations for decent back up batteries - as mine only lasts about 20 mins on a full charge
I have rubbish runtime on my battery too so have emailed the seller and got an £8 refund. Also need to source a good replacement
20 minutes! I am getting an hour and a half constant recording on the battery supplied.
I record as much of my training rides as the battery allows, so far I have got two close passes by a bus, a pull out by a Jag and an old guy in a Yaris who nearly took my right arm off when he insisted on overtaking me as I was signalling to turn right.
Best £60 i have ever spent.
I may drop the seller an email in that case - on the off chance they will either send me a replacement battery or a bit of a refund.
Either way I'm going to look into a couple of spares
I've bought a couple of spare batteries & a charger !.
Any links reedspeed?
I get about an hour recording, I did get about 35 minutes first time, not sure if the improvement was due to giving the battery a charge cycle or disabling HDR? My down button has now totally stopped working but got a full refund from accmart. To be fair I didn't find anything I need to use that button for, on and record is all I need! May have to speak to you at some point Steve regarding your soldering skills, if I can find a suitable replacement switch!
In age of £99 GoPros are these still worth considering?
the 99 quid Go Pro is an SJ4000 competitor with a brand name mark up. Whether you think its worth more is a different matter - it's 3 times the price of some of the cameras posted on this thread.
A mate of mine has a Go Pro 3. Having seen the camera I got from this thread and the footage it produced first time out he is a little p1ssed off.
I get about 80 mins from my battery no issues - they do some higher capacity batteries on ebay - but haven't bought one so can't vouch for the quality!
Higher capacity batteries (and charger) - [url= http://www.amazon.co.uk/gp/product/B00R4C2LXQ?psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s00 ]http://www.amazon.co.uk/gp/product/B00R4C2LXQ?psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s00[/url]
Mine arrived today and I'm charging them just now...won't know until weekend at earliest to see how long they last.
That's the same one I was looking at on Ebay
http://www.ebay.co.uk/itm/131386385613?_trksid=p2060778.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
For £7 posted its got to be worth the risk!!
Let us know how they do DickBarton
Will do...first one has charged so I'll go plug it in and see what happens!
no news on how the battery worked - does this mean it's blown up and burnt his house down?
Haha, sorry...new battery works fine, but I've not had a chance to use it so no idea how much longer it runs...
Second one is almost charged as well so I'll be able to try it twice to see if the run time is consistent between the 2 units.
Can anyone recommend a supplier with reasonable delivery times - 1-3 days if possible?
Also, how are folk getting on with the wifi version?
Cheers for the battery link.
Just ordered this
http://www.ebay.co.uk/itm/Xcsource-Cradle-Desktop-Charger-2x-1100mAh-3-7V-Battery-For-SJ4000-Camera-BC426/161533698456?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20140122125356%26meid%3D7ff6b66988984fdd9d14260d3a5ed874%26pid%3D100005%26rk%3D1%26rkt%3D6%26sd%3D131386385613&rt=nc&tfrom=131386385613&tpos=unknow&ttype=price&talgo=origal
for a twin pack for under a tenner.
Shame the battery cover is a bit of a faff to get off
After being told on Monday that my AccMart-via-Amazon purchased camera for £33.48 was being shipped by China Post (including tracking number!) it turned up today (3 days later!) with GB post-marks etc. Not sure whether I was just lucky or whether this would happen for everyone!
Camera looks and feels fine. Menu suggests it is SJ4000 with firmware dated 20140818V01. All feels good so far. Not entirely sure what some of the accessories do (the wire cable, the cable ties, the velcro bands, the arm bands), but will hopefully get a chance to try it out this weekend.
This was the link from which I purchased it [url= http://www.amazon.co.uk/gp/product/B00Q668ZGS ]AccMart Amazon link[/url]
It was nicely retail packaged
[img]
[/img]
Here's the firmware screenshot
[img]
[/img]
I've just taken the plunge and ordered this one - http://www.amazon.co.uk/Blueskysea-SJCAM-Camcorder-unterwasser-Helmkamera/dp/B00R74JMEM
I can't work out if it's 1080 or not. It doesn't say so, but I don't think that there is a wifi version which isn't 1080.
It's on prime, so if it's not 1080 I'll just send it back.
Fingers crossed.
Geoffj
That's v cheap Geoff If that's genuine sj4000 !
Cheapest I've seen anyway,as none wifi ones are normally £20 dearer than that ..
Geoffj - same as my original one - which developed an issue, so I sent it back, got a replacement and that had an issue, so I;m waiting on the replacement to that coming (should be today) - paid £34 delivered and it came from China, however my return and replacements are coming from somewhere in the UK (being returned to Croydon).
Whilst witing on the replacement I ordered up a Wifi version from Banggood - arrived 2 days later and cost me £54 (I think as they were doing a discount deal on first time buyer plus a January sale discount) - works very well, similar settings to the non-wifi I had but a later firmware. Like all wifi-enabled cameras, the app isn't awesome but is plenty usable but the lag between the camera and what is on the screen is very apparent (all my wifi-enabled camera devices suffer from this though, none are real-time, they tend to have a 1-3 second delay (and not consistently!)).
Lot is reviews of the WiFi one on banggood being fake though http://m.banggood.com/SJcam-SJ4000-WiFi-Car-DVR-Camera-Sport-DV-Novatek-Waterproof-p-939976.html
Dick - I looked at the banggood website, but the latest reviews on the wifi one suggest its not an original SJCAM. Have you updated the firmware or didn't you need to? It might be a good alternative if the one I've ordered isn't all its supposed to be.
Edit: What paulwf said
Just used mine for the first time, and all the colours look washed out, do I need to change a setting?
some footage from my banggood wifi sj4000 - seems legit going by the online pictures of real vs fake ones and not bothered to check the firmware. note not sorted the angle out just yet so mostly footage of a garmin dakota bouncing about & got stuck in a massive rut buy hey ho ok for first attempt
Did you use a chest strap gazc? Funkydunc try setting white balance to cloudy instead of auto
Geoffj that looks cheap if it's genuine. Otherwise is it worth spending 70 odd quid on one of these when the gopro hero is £99?
As far as I can tell, my Wifi is a genuine SJ4000, not tried doing anything with the firmware, seemed to be the latest or very recent one so just left it as it is. Works very well.
My replacement non-wifi arrived today, that seems to the same as larkim's...as far as I can tell it is also legit.
Even if it/they aren't, they seem to take good quality footage so I've no complaints.
The 5 quid chest mount on Amazon (cheapest one there) is very good. Mounting the camera upside down sits it at the right angle without needing additional mounts between camera and chest plate.
+1 for cloudy white balance setting, recommended on many sites.
Mine came unboxed, passes the "genuine" tests but dubious given it wasn't boxed, but most importantly I'm pleased with it, it works well and was a bargain.
and as we're posting test-ride vids for comparison here's mine with the view from the chest mount (with no editing in WMM so lots of shots of me fitting it...).
And [url= http://www.amazon.co.uk/Adjustable-Chest-Harness-Release-Buckle/dp/B00E95A14M/ref=sr_1_1?ie=UTF8&qid=1422562228&sr=8-1&keywords=Adjustable+Chest+Mount+Harness+%2B+Quick+Release+Buckle+Mount+for+GoPro+HD+Hero+2+%263 ]this is the chest mount on Amazon.[/url]
yes i had the cheapo gopro copy chest mount but dont think i had it tight enough. its a really rocky trail mind. have it mounted upside down with the curved arm mount
@CTM: that's recorded in non-HD mode, yes?
If anyone's looking for a case for them, this looks like a good deal.
http://www.amazon.co.uk/gp/product/B00JG4UR3G
so where to get a genuine one? surely if they are circa 60-70 quid youd be better off getting the basic go pro?! at 90?
especially if theres a chance its fake
can anyone link to a guaranteed genuine one please?
Wheres the cheapest for a genuine wifi version? I fancy taking a punt on one, or should i just get the non wifi model?
so where to get a genuine one? surely if they are circa 60-70 quid youd be better off getting the basic go pro?! at 90?especially if theres a chance its fake
The suggestion is that the sj4000 is better than the cheap gopro. Removable battery, housing etc and higher resolution (?) so even at £70 it might be a better deal.
The other point is that even the fakes appear to be good vfm, and only problematic if you need to upgrade the firmware.
To minimise risk, I'd buy from one of the eBay or Amazon sellers offering the sjcam name in the description and then check it against the guides when it arrives. If it's a fake, you'll easily get your money back.
Mine is due to arrive on Monday - I'll post here once I've had a play.
I mounted mine with the simple clip directly into the chest mount, no other mount used.
720p (not 1080HD) setting on camera, and didn't specify HD on Youtube upload so no idea how much compression they've applied.
is there any/has anyone got any actual mtb footage of 1080p hd for reference?
also crashtest which one did you get? tempted to take a punt if the 1080p hd is decent
one from the original link which turned out to be some Amazon affiliate referral so not sure which actual seller it was (was an Xmas pressy).
My 32" TV is 720p not 1080, and Youtube generally compresses, so 1080 quality was never a concern for me.
Here you go - but it isn't good. Front-mounted is a Drift HD Ghost; rear is the non-wifi SJ4000 - [url=
- I've now got a wifi and non-wifi version - both appear to be genuine SJ4000 products.
The wifi version I got from Banggood; non-wifi was from an Amazon seller - AccMart) - which was linked to from the first link on this thread.
Given the footage these are capturing, I'm not sure why I'd want a GoPro - I'm guessing the battery life is going to be comparable so I see it as a saving of cash.
My Drift HD Ghost is a very good unit, but it is heavy compared to these, the battery life on it is very good...about 3 hours constant, the GoPro's that I have had experience of don't have that good a battery life either - however, if you have money to throw at it, then go for a big name.
Well it's here
[url= http://i.imgur.com/YgstMfvl.jp g" target="_blank">http://i.imgur.com/YgstMfvl.jp g"/> [/img][/url]
[url= http://i.imgur.com/lHxh8JEl.jp g" target="_blank">http://i.imgur.com/lHxh8JEl.jp g"/> [/img][/url]
It is 1080 and wifi. The firmware (December 14) suggests that it is a a genuine SJCAM.
All functions seem to be working as they should - even wifi to an iPhone 5.
I'm pretty sure you don't want to see footage of me spinning on my chair in my study, so I'll post up something appropriate once I've been out - probably snow related. 😀
nice one geoffj - just post up a quick random vid please 🙂
interested to see the footage and if its decent ill order one right now!
do they just take standard go pro mounts? ie if I bought a gopro chest mount would it fit ok?
infact sod it - ill order one now
so I then need a SD card, any recommendations?
I tried ordering the silver one they sell but i keep getting an error. Might as well get the blue one.
oscillate - remember its a micro sd card - not the standard size one.... Sandisc 32GB class 10 with SD card adapter was around £12 from play.com if i remember correctly...
the camera i received from accmart won't update to the latest firmaware on teh SJ website and won't do timelapse so think its a fake - although housing etc appear to be legit....anywho going to send it back and might take a punt on another one as was looking for the timelaspe function...
£35! Eeek!
My fingers are burnt after the Belkin bib short debacle, but I am very tempted to get one of these!!
I succumbed! On the £5 chest mounts, it is [url= http://www.amazon.co.uk/Adjustable-Chest-Harness-Release-Buckle/dp/B00E95A14M/ref=sr_1_1?ie=UTF8&qid=1422894342&sr=8-1&keywords=go+pro+chest+mounts ]this one[/url]?
Also, any recommendations on cheap places for SD cards (micro or normal?)?
I'll admit to being really tempted but I'm aware that I don't really have anything to film beyond my usual speed mince (or not even speed, really, these days 🙁 )
is this a good card then mau00149??
im gonna try one, if its genuine then it does look a bargain
I'm using this card - http://www.amazon.co.uk/gp/product/B00D9OQ1JS
I'm going to have a look at the time lapse function now.
cheers geoff, let us know as im awaiting your testing now before ordering, got them hovering in the basket 🙂
EDIT : Geoff is that sc card only class 4? i thougght you needed class 10 to get the best out of these cameras?
Time lapse function works too although you can't adjust the time-lapse settings from the phone app over wifi.
Are there issues with maximum clip size? Review seemed to suggest that the files were limited to 4Gb each so recording would stop once you hit that size.
just ordered one! 54quid all in with a 32gb card class 10 and a chest mount
will see what its like hopefully pretty good 🙂
geoffj do keep reporting back as ive gone off your recommendation 🙂
I have 2 spare batteries and a charger for these .as my camera was faulty . £5 posted if anyone wants them
Dunno - not filmed anything that long yet, but 4 gb would be about 30 minutes (at 1080). The 4gb limit may be a file system restriction, but I'm not sure I'll be filming clips that long anyway.
Yes the card is class 4, but I've just ordered a class 10 now 😀
I may be able to take something not completely dull tomorrow.
