£60 at JTF. The thing is massive! Bargain!
Edit*
Cheap pressure washers as well
http://www.jtf.com/catalogsearch/result/?q=%22pressure+washer%22
I guess it's [url= http://www.jtf.com/hilka-procraft-parts-washer-20-gallon.html ]this one[/url]...
[url= http://www.jtf.com/rac-pressure-washer-1500w-with-accessories.html ]This one ?[/url]
[url= http://www.jtf.com/hilka-procraft-parts-washer-20-gallon.html ]this one[/url] innit
How do these work? Is it just recirculating degreaser with a pump or do you need to plumb it in or something?
Also is this one overkill for cleaning bike stuff? And is it actually worth having one? I hate cleaning stuff so anything that made it easier would be considered!
They recirculate, I use one for cleaning engine parts and with the right fluid it works wonders!
Personally I think its overkill for bike parts, but I do occasionally use it for bike parts as it's a lot quicker with the right fluid.
Its a 20 gallon container so must be massive, I guess you could stick the whole bike in there 🙂
That is a good price, be aware you`ll need a 25L tin of Jizer or equivalent to even make it run so its over £100 in degreaser to use it
The bench top ones do the same job on smaller parts for less fluid
