Currently £69 with the clearance code. Not bad for cranks, chainrings, and a BB
almost bought a set as spares 🙂
Clearance isn't bad this time around. So far I've picked up most of an unfashionable XT 2x10 drivetrain (including that XT crank) and some nice carbon bars and used the code three times.
The older version of the Xfusion Sweep looks a decent deal at 340 with the code or 315 with BC discount.
Pffff. I've got a BNIB XT double that I missed the return window for. Looks like that's £50 tops now then.
Nice one 😀 spares bought for FS, will likely get fitted next spring ! Would have preferred black but at £70 not complaining !
How long have you had it as...
We are obsessive about your experience – from our award winning support centre to our 365-day returns policy – we make sure you’re covered!
yeah. erm. a bit longer than that. 😳
Price dropped to £71.99 for the cranks. However, this means the £10 off code is no longer valid as you need to spend £75
You need to add something for £3.01 then 🙂
funnily enough (given your user name) I bought a new 24 tooth inner ring for £4.99 🙂
Thanks 🙂 Also ordered with a 24T ring.
Didn't take long for the profiteering to begin 🙂
Do CRC still have them?
No, sold out at that price. Ribble seems to have them for 83 in a 26-38 flavour.
I very much doubt scan2004 will look into this forum 😆 but if he is that desperate for his £15 minus postage, then hey, some might see it as a bit off, but it's not like he's robbing pensioner's. He would have to have bought a heck of a lot of them to be making his fortune.
Plus the price was a little bit higher when I bought some at the start of the clearance. 👿
So he's probably making virtually nowt on the deal whatsoever.
