Cheers, need some pads for some second hand Deores.👍
Thanks! Brake pads bought
Bugger, placed an order earlier today with 20% off code.lucky for me its only a couple of quid difference. ๐
Are they going bust as well then ?
Shouldn't think so. Not stopped you thinking so on the last two PSA threads
Are their rotors any good?
Got them on a few bikes. Never had a problem with them
Out of stock on all compounds for Hope X2 🙄
Decent thanks. Hope pads ordered
Thanks, pads ordered.
Superstar also 25% off everything with code 25SNOWY
I briefly ran their floating rotors and wasn't that impressed
The the disc brake rotor started to separate from the carrier so there was a couple of millimeters of play under braking (happened after about 4 months use)
They did warranty them without issue, but it was enough to put me off so I went back to Hope instead - the replacement Hope ones were the same size and have performed without any issue since
