Anyone know so i don't need to take my bike apart!! cheers
bump
and again
swing arm bearings 6902
ta - 2rs i presume? Getting a new swing arm - will it come with bearings fitted?
Ask your lbs
is it open - is i ****!
rs is right good luck with swing arm fitting it yourself?
aye - easy enough
pppppp
racing_ralph - Member
proper proir planning prevents p155 poor performance
you did start this post 2 days ago
the swing arm arrives in 3 weeks! POYPT
15 x 28 x 7's
Try EBR Bearing Supplies on fleabay
thanks dusty
They're the ones. I use a big bolt, some washers and a big socket to fit them. So, big socket on outside of swingarm (bit of tape on there to protect), big washer to stop bolt pulling into socket, press bearing in by hand as square as possible as far as you can, then washer just smaller than bearing o/d - about 26mm - then the nut and carefully tighten. Did that make sense?
A big G-clamp may do it too with care.
i have a metal work vice and a bearing ress so should be ok 🙂 cheers matey
Very semi-pro 😉
are [url= http://cgi.ebay.co.uk/6902-2RS-61902-2RS-SKF-RUBBER-SEALED-BEARING-15X28X7mm_W0QQitemZ400035439314QQcmdZViewItemQQptZUK_sportsleisure_cycling_bikeparts_SR?hash=item400035439314&_trksid=p3286.c0.m14&_trkparms=72%3A1683|66%3A2|65%3A12|39%3A1|240%3A1318 ]SKF bearings[/url] worth £7 each more?
SKF are standard C/dale fitment, strange that the PDF manual for the Gemini lists the size and manufacturer, but there's no reference to the bearings in the Prophet one other than the C/dale part no.
SKF are premium quality bearings I believe.
SKF it is then 🙂
Because you're worth it...
