I fancy fettling again and would like to try a bolt up rear axle - how much and wheer from for a prophet MX rear end/swing arm?
seconded
very pricey just to try, what's the matter with the QR one?
nowt - ust fancy it - triggers broom syndrome
bump
I would quite like to find where I can get a cheap prophet frame from.
buy a crap prpphet and strip it - cheapest method i think. Not sure if cannondale do frame only deals
I might get a SH one from fleabay strip the parts put an rp23 on it and all my parts.
More money than sense some people
I know Will, I know!! Back end was flexing when out the saddle last weekend so if its under £100 then worth a go imo
Think youll find a new one would be over £200
elimitaed duff bushings / bearings?
Doubt you'd get it under £100
Did you not explore the RWS and through axle adaptor?
obviously not if i am asking about the new swing arm 🙄
New bike
OOOh get you. 😛
spoke to leisure lakes who quote £289 for anew swing arm - will leave it i think!!
flexing? you? was someone else riding it??? 😉 😉
drill it out and then put some threaded bar through - jobs a good 'un.
Have you thought about emailing C'dale and asking if they have an warrenty failure MX frames with a backend you could buy from them?
(every frame has failures after all)
Can it hurt to ask?
servicedeskeurope@cannondale.com
