Ok so getting a new bike with rear shock with propedal when do you use Light , Med ,Heavy (no sure of the last setting ๐ณ ) Shock is Fox Float RP23
Does it relate to the incline your going up?
Light Fireroad
Med Trail
Heavy (or what ever its called) BIG climbs!
As far as I know it only relates to when it's in lockout mode and it's for when it blows out, For what it's worth I am 76kg and use to have mine on 2 (medium) it's a case of set and forget. I'd ride it with each one and see which gives the best support/comfort.
one end is 'super squishy' (for the descents) - i guess 'light'
one end is 'firm pedalling like a ht' (smooth climbs) - i guess 'heavy'
the setting in the middle, removes some of your pedal bob and still reacts to square edged hits.
as above, this is your fit and forget option
The 1-2-3 settings are the level of propedal, the lever switches the propedal on and off, choose the level of propedal which suits you and your bike and weight then use the lever to turn it on and off while your climbing or descending.
Once you've decided what level is best you shouldn't have to change it while you're out, just use the lever to turn it on and off..
It's a low speed compression circuit which is designed to cut out the pedal induced bob (low speed osscilation)
1,2&3 are soft medium and hard on the RP23 (varies depending on tune as to the effectivness)and the lever turns it on off. (although the adaptive logic ones set the pp in off position 0,1,or 2 and the on was full pp)
It'll depends on what linakage and setup you have on your bike as to where you set it.
I'd start with it in 2 and turn it on and off as you see fit and then adjust from there. ๐
get a better suspension design where you don't need it...
DW link on your Turner, Turnerguy? ๐
maybe ๐
maestro doesn't seem to need it much either.
Cheers guys ๐
Loco - set correctly it also helps "stall" in rollers yes?
It'll support the back end more in low speed compressions , so yes would help in rollers and berms too, I used to run a bit on downhills to give a bit more support and something to push again and pump stuff.
FWIW my pro pedal lever seems to do nothing. I am not even sure which way you flick it to turn it on.
A google seems to reveal this comes up a fair amount
^ it is hard to tell when static but it is really handy. I keep it simple and just put on (set to 3) uphill & on flats and off for bumpy descents . It's a RP23 TF tuned on Canyon Nerve
They're due a service every 12 to 18 months (200 hours) so it maybe a nitrogen leak into the oil causing areduction in damping, this is pretty common at service time.
