Problem setting for...
[Closed] Problem setting fork sag (stiction)
Hi all,
I'm having trouble setting the sag on my forks...
I am getting on the bike very gently and then standing up in the attack position fully loaded with gear. It seems that half the time the forks barely budge at all and then the other half they suddenly release and dive (perhaps when I'm putting slightly more weight over the front). So the sag reading is never the same and varies massively.
I've sprayed the stanchions with silicone spray to see if this would get them to stop sticking but no joy.
Has anyone else come across this problem?
Rob
Posted : 26/07/2013 4:20 pm
 br
Yep.
Just roll with it and it's only an approximation - just take a shock pump out with you the first couple of rides and alter as/when.
Posted : 26/07/2013 4:21 pm
I'm more inclinded to set them up so I get full travel on a hard ride.
Posted : 26/07/2013 4:47 pm
Ah that makes sense, thanks.
Would it be best to dial in the air pressure before starting to mess around with the rebound setting? I.e. stick the rebound to middle to start off with, get the pressure right so that it just about uses full travel on the biggest obstacle then start tinkering with rebound?
Posted : 26/07/2013 6:08 pm
Yes, I like to set the spring first, then the rebound, then the compression. I find the adjustment with the most noticeable effect goes first, then in descending order. If not, something like compression adjustment gets blown out of the water when you swap springs or ramp up the air pressure.
Posted : 26/07/2013 10:06 pm
Why? Get on the bike and bounce it around the place until the suspension settles into its natural position, then measure from there (push o-rings against seals, etc)
Posted : 26/07/2013 10:14 pm
I find it best with a helper.
Put bike near a solid wall or fence. Get on bike, attack position, bounce around a bit, let it settle. Get friend to make small mark on stanchion next to wiper with black marker. Viola. The mark doesn't last for long.
Posted : 26/07/2013 11:06 pm
