I'm swapping from a float R which has full time propedal to a RP which has a lever.
Am I right in assuming that the RP is fully active unless PP is engaged and basically I can turn PP on, set the threshold and then forget about it? I don't want to be switching back and forth and the bike is bobby without PP.
Thanks
J
Posted : 10/02/2010 5:07 pm
The - position is full open, the decal on the side of the shock will show the level of pro pedal tune it has. If you set the correct rebound speed it should nt be bobby. What shock is it ?
Posted : 10/02/2010 7:43 pm
