Pro 2 - sticky free...
[Closed] Pro 2 - sticky freehub - service time ?
Haven't used this for a couple of months due injury , but I have noticed that the freehub is sticking when backpedalling (in workstand, as I am still off the bike). It frees up if I rotate forwards, but after say 10 mins left stationary, it's sticky again - I am guessing it is strip and service time ? (I haven't had Hope hubs before, more used to shimano, this one has seen about a year of light/moderate use)
Posted : 17/10/2009 2:12 pm
The free hub is very easy to service. Could be the pawl springs are gummed up by the thick factory grease.
Posted : 17/10/2009 4:54 pm
Yep just regrease the pawl springs easy job!
Posted : 17/10/2009 5:05 pm
Could also be the bearings starting to sieze, not unheard of with Pro 2.
Posted : 17/10/2009 5:58 pm
The bearing in the freehub (outer) is usually the first to go (in fact IIRC it's a pair together)
Posted : 17/10/2009 6:00 pm
Also worth checking your jockey wheels, if sticking can cause back pedalling sloppy chain syndrome
Posted : 17/10/2009 6:08 pm
 RicB
Just pull the freehub off with the cassette still attached. 20 sec job to see what's seized and what isn't. Unless you axle is seized onto the bearing races, in which case it'll take a bit of a heave to shift it.
fwiw I bet it'll sort itself out after a few miles of riding. Ask a mate to take it for a spin before stripping it down.
There are 3 bearings in the freehub and in my experience it's the outer one that goes first. Pop the seals off the bearing, soak it in white spirit for a few days and repack with grease. Should be good as new ๐Ÿ™‚
Posted : 17/10/2009 6:35 pm
thanks all - was the freehub bearing a bit gummed up - cleaned out and regreased and all ok ๐Ÿ˜›
cheers
Posted : 17/10/2009 7:24 pm
