Pro 2 Mavic 717 Hop...
[Closed] Pro 2 Mavic 717 Hope Hoop tubeless conversion
Anyone managed to do a tubeless conversion on these. I assume it can only be done with the £50 Stans conversion kit rather than the cheaper hope version if its at all possible ?
Posted : 01/11/2012 11:17 pm
From conversations with my LBS just done some mavic EX721, yellow tape a valve and some sealant works in most. Rim strips optional.
Posted : 01/11/2012 11:20 pm
Cheers - Was that the Hope conversion kit then (Comes with yellow tape and a valve) and you didn't change your tyres for owt else then ?
Posted : 01/11/2012 11:28 pm
My 717 rims went up fine with just the yellow tape and some valves cut from some old inner tubes. Was on schwalbe tubeless ready tyres.
Posted : 01/11/2012 11:36 pm
 Haze
Stans strips, one layer of yellow tape and tubeless ready NN's.
Struggled a little to seat the rear but the front went up fine and stayed up first time without sealant (not that I run it without).
Posted : 01/11/2012 11:39 pm
I had some rim strips kicking about and used them for belt & braces approach.
Not sure what tape you got, but I used the stans stuff the LBS had - it was a Friday pm with beer and BS job 🙂 Used new tyres as I had too much tread for local riding. There are a few variables with tyres etc. Best bet is to have a go and see what happens 🙂 Finding somewhere with a compressor will make life easier and someone who has done it before. As above my lbs is happy with the Fri PM beers so good time to play about in someone elses workshop.
My 717s weren't close to working with yellow tape... I got a half-decent result with tape and BMX tubes but still burped frequently, and rolled right off once in a hard corner, not nice. So I sacked them and got proper tubeless rims, never looked back.
Posted : 02/11/2012 12:04 am
Not 717 but got a result with the hope kit on 719.
Two wraps of tape. Had to use a ghetto inflator to seat some new conti folders
But all seems well now.
Posted : 02/11/2012 1:13 am
Not had the greatest luck with 717's tbh, mainly go up, but plenty of burping...
You'll be wanting [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=78506 ]these[/url]
and [url= http://www.wheelpro.co.uk/wheelbuilding/book.php ]this[/url]
Posted : 02/11/2012 10:14 am
Got 717's working fine. Removed rim tape and just used Gorilla tape. Been up for ages now. Were more of a faff than my 5.1's but definitely possible.
Posted : 02/11/2012 10:31 am
The 717 is pretty narrow so you'll want something like this:
http://www.chainreactioncycles.com/Models.aspx?ModelID=74011
I run 717s with a tubeless Spesh Storm/Captain combination on my hardtail and it's behaved perfectly. I didn't even need to use a compressor, it just inflated pretty nicely from a track pump.
I use the normal Joes XC width strips on my XM719 equipped full suss bike.
Posted : 02/11/2012 10:40 am
Did a conversion on a mate's wheels the other week, these exact rims.
5 wraps of this: http://www.ebay.co.uk/itm/150333028414?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649 which coincidentally is the tape Stan's used to recommend before they started to make strips.
We used these valves: http://www.ebay.co.uk/itm/310407534562?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
Little trick is to take the valve cores out when doing first inflation and have them ready to F1 style refit. Helps you get loads more air in quicker and seat.
We were using standard Minions and a track pump. Went straight up, used 2 cups of Stan's fluid and have worked perfectly with no burping at all.
Posted : 02/11/2012 10:41 am
