Presta vs schrader ...
[Closed] Presta vs schrader valves
my general understanding was the presta are better for higher pressures?
So why do air shocks running at several times the pressure use schrader valves?
Posted : 22/08/2012 1:11 pm
[quote=jam bo said]my general understanding was the presta are better for higher pressures?
schrader are more robust valves. If you mangle presta valve on an inner tube then it's a pain but not the end of the world. Do it on your expensive forks/shock and ouch! You can easily replace the valve core of a schrader also.
Posted : 22/08/2012 1:13 pm
