The humble valve is one thing which somehow seems to have escaped being updated which I find odd. Has there been an alternative design other than schrader? I guess it should be possible to do while still using the same pump? Gripes I've found:
- For some insane reason valve cores unscrew in same direction as the tip leading to accidental total releases of air.
- They are delicate and get clogged easily.
- Its easy to jam the tip screw and end up requiring pliers to undo them which most people don't carry on the trail.
- They are narrow and restrict airflow making it harder to pump than necessary.
There has to be a better way!
Schrader? and before anyone says high pressure take a look at your shocks
Nope, never
Nope, never
Nope, never
Marginal at best
This thread is proof that some folk should never attempt bicycle maintenance.
Had them unscrew when used tubeless and gunked up
Had them clog when used tubeless
Bent the tip on quite a few
I'm thinking more of a redesign of the valve core itself.. far too many presta drilled rims out there to go back to Schrader. Could be another great way for the industry to force us to buy new wheels again 😉 I guess now rims are so much wider there is plenty of space for Schrader drilling
I had a pump that sheared off the valve every time I used it 😀
Strange response.. guess you don't run tubeless?
Removable cores and Lezyne pumps = AAAAAAAAGGGGHHHHH!!!!!!
[i]"Has there been an alternative design other than schrader?"[/i]
[url= https://en.wikipedia.org/wiki/Dunlop_valve ]Woods valve[/url]
Guess again?guess you don't run tubeless?
Once bittenRemovable cores and Lezyne pumps = AAAAAAAAGGGGHHHHH!!!!!!
I've had them get gummed up (with latex), but never to the point that they clog completely. I've also bent the ends a few times (absolutely no idea how!) and have also unscrewed the valve core by mistake on the trail.
That said, I still prefer them to Schrader valves and they're not top of my list of things that need a new standard...
Yep had that happen to me yesterday with my new Lezyne - the straw that broke the camels back hence this thread!
My Lezyne pumps headed to the bin. Now use Topeak which have the lever action clamp. This is for both road and MTB.
It doesn't happen if you remember to tighten the core up fully with pliers or the proper tool. But some manufacturers (Continental, I'm looking at you) supply tubes with the cores fairly loose.
I have one of those valve core tools (only £1 from Wiggle) in my kit for those 'just in case' moments if a pump unscrewed a valve core or something similar. Only ever had to use it once on the trail but it was worth having IME.
Unscrewed the presta valve caps yesterday to pump up the tyres, bloody valve core unscrewed as well, lost all air out the tyres.
Managed to separate valve cap from valve core, sprayed a bit of GT85 on the threads and reassembled. Hopefully that might stop the two sticking together.
For years I ran Schrader valves as i found them easier in use (can use a car tyre inflate or garage tyre pump :-)).
Since going tubeless I've (ha??) To use Presta.
No.
Yes all those things happen to me, but if the bike industry redesigns them they won't work with existing pump, they will take special shimano tire jelly not air, and for some inexplicable reason necessitate the buying of a whole new bike.
Never thought to carry a valve core tool - a spare core would also make sense
Thinking about it, I think the only time I've ever unscrewed a valve accidentally was on a Conti tube, while using a wide WTB dust cap.
That's more a design issue with the shitty lezyne pumps.
The moment when you absent mindedly think you're unscrewing the tip, unscrew the whole thing, which is then jetted out of your fingers across the car park...
Of course they're not perfect and the valve stems can get bent or the core unscrew - but they're not going to change any time soon. If anything they've got more dominant over the last decade.
I read a good opinion piece on one of the US bike sites, with the author pointing out all the flaws but quoting some industry guy saying that roadies would want to keep them for the "prestige" image.
I have one of these in my bike tool bag:
http://www.wiggle.co.uk/lifeline-valve-core-remover/
I don't bother carrying a spare valve core as I have one by default in the spare tube, but the tool has come in useful before now.
^ yes that's the one I have too.
IHN - Member
Nope, never- They are delicate and get clogged easily.
Nope, never- Its easy to jam the tip screw and end up requiring pliers to undo them which most people don't carry on the trail.
Nope, never- They are narrow and restrict airflow making it harder to pump than necessary.
Marginal at best
A typical STW response. 🙄
I've bent the stupid little threaded bit and even broken one off on one occasion when using a mini pump on the trail. Hate the stupid fiddly little things with a passion but they do seem to be the default with most rim manufacturers. Alienation BMX are at least enlightened with their rims being drilled for both and supplied with a couple of bungs to plug the gap [url= http://www.alienationbmx.com/parts-2017/mischief-rim ]Alienation Mischief[/url]
Schrader are better in almost every functional way but they're a fraction heavier and require a bigger hole in the rim which is I suppose why most rim manufacturers shy away from them. I'm not ghetto drilling out my rims to fit them even though it pains me every time I have to go near the damn stupid roadie hangovers.
IHN - really?
My experience is -
Bent the tip on loads over the years to the extent all my trail/pocket pumps now have a hose.
Always remove the cores to set up new tyres tubeless with an Airshot. Rarely works if I don't
After buying a bike with Stans rims supplied with Schrader tubeless valves with removable cores I can confirm there really isn't ANY advantage to using presta.
They're just better, none of the negatives outlined above apply. The only point to Presta is to fit the hole in a narrow rim. Now we're all on 30mm rims can they please be consigned to history.
Joe's No flats do a schraeder option. Works fine.
Presta is some weird hangover from the roadie world of narrow rims. Bin the hateful things!
HN - really?My experience is -
Bent the tip on loads over the years to the extent all my trail/pocket pumps now have a hose.Always remove the cores to set up new tyres tubeless with an Airshot. Rarely works if I don't
Spot on.
Though, we are in the presence of bike maintenance gods.
Glad I'm not alone in my hatred of presta valves! It seems odd that almost all old standards from road bike days have been updated, often with only marginal gains, but that valves have escaped the treatment. They feel like an irritating relic from 50 years ago that has somehow snuck into the modern MTB.
And the rims on my newish road bike are the same width as my oldish mtb...
Simple thing to do would be to use a presta stem with a screw on adapter with a Schraeder core, plus a good quality cap capable of sealing the pressure if the valve core leaks.
Wizards!! FFS can you not get [i]anything[/i] right?Nobberinthefridge - Memberwe are in the presence of bike maintenance gods.
Wizards
You're certainly old enough....
FWIW, I don't 'hate' them, I'll continue to use them unless something better comes along, but they are not without issue, especially tubeless.
It's Conti tubes that are the issue. Cheapo Wiggle own brand are fine.
Funny how this problem never raises itself in any review of a Lezyne pump in any magazine, anyone would think it's some kind of conspiracy.
OP you could always move over to woods/dunlop valves.
Never had a problem with them but I remember watching matey inflating a tyre one day and
yupvalve cores unscrew in same direction as the tip leading to accidental total releases of air
yarpThey are delicate and get clogged easily
fortunately I had my electrical pliers with me 😉Its easy to jam the tip screw and end up requiring pliers to undo them
All part of life's rich tapestry eh
IHN - really?
Really
My experience is -Had them unscrew when used tubeless and gunked up
I'm still on tubes, so that may be a factor. I've bent the tip on a fair few over the years to be fair, but it's never mattered, they've still done up enough to 'lock'.
To be fair, any type of tubeless valve can be susceptible to the locking loosening which means that your ride ends as loads of sealant comes jazzing out of the valve hole.
I find that the valve ends of Presta valves are easily bent and damaged, so I carry spare valve cores in my Camelbak along with a small plastic tool to unscrew and replace.
I suspect that like many of you, I have been known to take a Black & Decker to my brand new rims so that they will take a schraeder valve though.
After having to reinflate a bent one in the middle of nowhere only to have it snap off thanks to the combination of my ham-fistedness and a presta's fragility, both of these items live in my pack.
Tubeless gunk blocking the airway is quickly remedied, but more of a preride problem ime
Snapped loads of them, usually with hand pumps. But not often enough to make me want to change.
Any time wide enough gets drilled for Schrader valve. Presta valves offer no advantage but plenty of disadvantages.
I'd be happier if schrader valves were consigned to history. Ugly things.
Well I can't see anything lightweight being immune from damage, I can't see any valve design not being susceptible to tubeless spluff, and I don't think high flow is a necessity when you can remove the valve core when you need it.
If it was wider, it would be a bigger hole in your rim. I guess with tubeless you might need to top up the air so it could be a bigger problem in future than it has been in the past (they've only ever been stuck when I've needed to do something in the workshop - I wouldn't top up a tyre on the trail/road generally, and if I'm fixing a puncture I don't need to undo the valve on the old tube).
So I can't see it being replaced, despite some problems.
What is wrong with shrader valves?
They seem to work fine on the millions of cars, vans, lorries etc. Work fine on my bike too, but then so do presta.
